Old 2015.08.03, 03:32 AM   #1
Pinger
X-Power IDT
Did anyone try out the new IDT?!
Thank you
Pinger is offline   Reply With Quote
Old 2015.08.03, 03:38 AM   #2
Pinger
X-Power IDT
Hi folks,
Has anyone tried the new IDT?
Cheers
Old 2015.08.04, 02:22 AM   #3
DMALMAD
DMALMAD's Avatar
IDT
http://mini-zracer.com/forums/showthread.php?t=40083
and
IMT
http://mini-zracer.com/forums/showthread.php?t=40222
I have tried almost every Mini-Z related chassis currently avialable and I can honestly say stear clear of the IDT and IMT. I own both along with multiple MRX and have made my own aftermarket chassis and can say with confidence that spending money on the IDT / IMT is a mistake. Stick with an MR-03, and MRX, or an 020 if you want AWD. Anything else is overcomplicated and poorly excecuted.
Old 2015.08.09, 03:26 AM   #4
AFMiniz
My view is they (miniz and IDT/IMT) are two different classes of RC.
Miniz started with a "toy" concept and is targeting the mass market though a lot of 3rd parties brands produce option parts to make it becomes "raceable". MRX is another break through to push the miniz concept to its upper limit in term of racing capability.
Whereas IDT started from an ordinary RC concept as if it was a touring car and is targeting the RC players market. It's raceability is on its hardware like use of sensored brushless technology which has never been used in such small scale RC. The kind of enjoyment is totally different.
AFMiniz is offline   Reply With Quote
Old 2015.08.09, 06:23 PM   #5
DMALMAD
DMALMAD's Avatar
It is not enjoying when the car is fragile, unpredictable, poorly made / designed, and it handles poorly. And to top it all off it is faster with the sensorless, just my luck Yes the concept was good but the car itself is a nightmare. If you never experienced how well a regular Mini-Z can handle and perform than I guess ignorance is bliss but from the standpoint of being economical and having a RELIABLE car that you can count on to handle decently the X-Power IDT/IMT would be my last choice of 1/27th or 1/24th scale equipment. Just my opinion, but then again I have spent money and raced all versions of X-powers cars so what would I know. Not trying to call you out, your experience might be good, but there is a reason that a whole bunch of people bought them at my track and then only ran them for a month....
The car is heavy, poorly balanced, prone to tweaking, and does not even come with enough caster. In their design you change the wheelbase by shimming the lower arm but at the longest wheelbase you get at max like 1 degree of caster but when you shorten the wheel base at the front you get negative caster. That is just one of the many design flaws but overall the car is not worth the hassle or the money. If sold at 350 rtr with half decent spring rates and the proper hub and caster block front suspension that allows adjustmen of camber at the front then maybe the car would be half decent. Even then the roll centers on the car are way out of wack, and the ballstud is not long enough to shim to the correct height. The bellcrank (which is a 60 dollar option on a 560$ car btw) allows less steering throw then the draglink (which provides unequal bumpsteer). Not only that but the car comes with 1 degree rear toe and requires optional blocks at 15$ a piece (standard 1/10th tc come with 3 degree rear toe standard which is a much better starting point). X-power passed off a sub par car with decent electronics for too much money.
In the case of the Mini-Z v.s. the IMT (which is direct competion to the AWD) the IMT is the gimmick toy and the Mini-Z is the race platform. There is a reason why there is a strong aftermarket for the Mini-Z, because it is an excellent base plateform with immense potential (aside from the t-plate). You can only go up from the base 03 but the IDT/IMT are lower than the Mini-Z and can't go up or improve.
X-Power did a great thing with the sensored technology and the idea of the scaled down TC but after showing the car to 1/10th tc guys they had no interest and still considered it a toy. So the one purpose it served (to bridge the gap between TC and Mini-Z) it failed at.
Yes I feel cheated by X-power and that is the origin of my statements but the reality of it is that everything I have said about it is factual and leads to only one logical conclusion: The x-power IDT and IMT is inferior to the MRX and 03 in every way except for its electronic speed control and sensored technology.
Old 2015.08.10, 10:19 AM   #6
hum3
I have a different view.
I have been a big RC fan for more than 15yrs. When I had no family, I used to spend all my time on RC cars. Spent the evenings over the week to cleaning the car.. the bearings, tuning the engine, spraying the Lexan bodies.. then racing on the weekends...
Unfortunately, life changes when you have a wife... and kids.. I still love my RC but I can only spend 2-3 hrs a week without getting into trouble...
I started doing Mini-Z, MR03 first but I really missed my full throttle sliding out of the corners. MA was good for a while until the motors becomes too powerful. I kept breaking everything .. plastic gears are smooth but I hate having to replace them every few weeks .. and I could never make the metal gears running smooth with each other ... hard plastic shells are nice to look at but cracks easily.. whenever I broke the chassis... I would be out of action for a least a few weeks until I finally found enough time to rebuild everything..
I have owned the IDT for a few months now, a few parts still wears out from time to time, but they are super easy to replace. My 2-3 hrs each week have been spent running rather than fixing the car. It was more expansive to buy up front but a lot cheaper to maintain in the long run. The ball diff requires some fine-tuning from time-to-time so I am still missing the oil diff from my 1/10 days
hum3 is offline   Reply With Quote
Old 2015.08.03, 06:47 AM   #7
AFMiniz
I did. I bought a IDT SPORT as a start, then upgraded it with options (including sensored motor). I enjoy its "touring" feel very much.
Old 2015.08.04, 08:59 AM   #8
AFMiniz
My IDT
Old 2015.08.11, 09:56 AM   #9
Pinger
Thanks AFMiniz!
Is there any other info?!
FS: 2 x PN Racing S6 Chargers and 1ntegy PS10 Power Supply RussF Mini-Z Marketplace 1 2012.04.24 10:36 AM
PN Dual Charger system with stand and power supply Roger Mini-Z Marketplace 4 2011.06.27 12:15 PM
V2 Power Board TinRacers Atomic 1 2007.06.14 12:07 PM
Making a power supply out of a PC power supply unit arch2b Mini-Z Science 18 2005.07.24 07:40 PM
Alternative Turbo Power Installation Mondo Setups 16 2002.04.02 07:23 PM
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
