Old 2013.10.11, 11:05 PM   #1
r46
r46's Avatar
Coming soon:Turnigy TZ4
just see launch vid/review
http://youtu.be/GTYU05o1E7k
egrmart has them (but why no decent body )
http://www.egrracing.com/shop/index....oducts_id=5597
http://i810.photobucket com/albums/zz24/triks75/Wlmr-blue-sm jpg
Dnano
#911 #Enzo #Lambo
Motoracer x2
02ex Hfay
02mod
03 Hfay
03 mod
03VE
F1ve
020 50t
030evo
AMZ
GL racing Rider
TZ4
reserved for
r46 is offline   Reply With Quote
Old 2013.10.12, 05:53 PM   #2
Exciting to see commercially available options to Kyosho but not a fan of lexan bodies in general. I love our scale for the detailed scale.
Old 2013.10.13, 12:08 PM   #3
with the commercial release of this chassis, it is no longer aftermarket and it now has a new home
Old 2013.10.14, 11:11 AM   #4
fastmax
RCP Me!!
fastmax's Avatar
These definitely have my interest. Guess I'll have to order one and see what it's all about.
GoFly
Helifar
Kyosho
Goodrich RC Club
fastmax is offline   Reply With Quote
Old 2013.10.14, 07:50 PM   #5
RCPMini-z
rcptracks.com
Want to order one up myself.
Old 2013.10.15, 01:11 AM   #6
r46
r46's Avatar
Same when I get one gonna see if M1 can fits an see how long drive train lasts then attempt a brushless conversion if gears held up from first exercise
Dnano
#911 #Enzo #Lambo
Motoracer x2
02ex Hfay
02mod
03 Hfay
03 mod
03VE
F1ve
020 50t
030evo
AMZ
GL racing Rider
TZ4
reserved for
Old 2013.10.17, 06:57 AM   #7
r46
r46's Avatar
now available but had a name change- Turnigy TZ4
http://www.hobbyking.com/hobbyking/s..._Car_BND_.html
Dnano
#911 #Enzo #Lambo
Motoracer x2
02ex Hfay
02mod
03 Hfay
03 mod
03VE
F1ve
020 50t
030evo
AMZ
GL racing Rider
TZ4
reserved for
Old 2013.10.17, 08:50 AM   #8
RCPMini-z
rcptracks.com
Have a car and radio on the way. Will post review, shortly.
Old 2013.10.17, 01:01 PM   #9
Features:
• Carbon Chassis
• Rubber Tires
• Full ball bearings through-out
• 5g Servo
• 130 Brushed motor
• Full proportional control 2.4ghz Receiver
• 3 in 1 Receiver, ESC combo
• 650mAh 7.4v 2 cell Li-Poly battery
• Polycarbonate body shell
• Kyosho Mini-Z compatibility with body shells and wheels/tires
• Included Charger
Specs:
Motor: 130 class
Weight: 164g with battery
Wheelbase: 104mm-110mm adjustable
Width: 70mm Adjustable with Rims
Requires:
Any HobbyKing GT series car or FlySky protocol Transmitter
i would like to see how this is done.
The TZ4 AWD mini touring car is a mini size RC car with a Big guy attitude…The new Touring MINI-Q chassis has all the features of its bigger 1/10 scale brother from tunable suspension and chassis set up to swappable Lexan bodies and adjustable wheelbase.
so the kit is called TZ4 utilizing a Mini-Q chassis? TZ4=Mini-Z, Mini-Q=chassis type? need to know how to properly categorize this.
Old 2013.10.17, 02:30 PM   #10
fastmax
RCP Me!!
fastmax's Avatar
Awesome! Look forward to hearing your thoughts.
GoFly
Helifar
Kyosho
Goodrich RC Club
Old 2013.10.17, 05:09 PM   #11
r46
r46's Avatar
since the video hobbyking/ Turnigy have changed name to TZ4 maybe because factory had released product already under mini Q
We can clearly see use's mini z wheels wonder which awd or 2wd?
Dnano
#911 #Enzo #Lambo
Motoracer x2
02ex Hfay
02mod
03 Hfay
03 mod
03VE
F1ve
020 50t
030evo
AMZ
GL racing Rider
TZ4
reserved for
Old 2013.10.21, 08:55 PM   #12
xmodcanuck
In one of the pics you can see on the side a mini-z type body clip notch. I would imagine the posts are removeable.
I'd say based on the center screw and ?washer/bearing? that they're using 2wd style mini z rims.
Old 2013.10.21, 11:04 PM   #13
unearthed name
so any reviews? i would like to buy one. but i need to buy new remote probably
Old 2013.10.23, 05:38 PM   #14
gctkaz
Yea, I'm pleased to see the side posts there, but I haven't had a good look at how the front nose clip will be installed.
I'm more convinced that AWD rims are being used. There are more pictures from HobbyKing's site taken from different angles, you can get a better look at some of the parts and it appears as though AWD-style knuckles are also used, which would lead me to presume some compatibility with AWD swing shafts and differentials. My only remaining concern is the servo dimensions and spline size. We're used to having super fast steering and the only (reasonably-priced) micro servo I have come across so far with an adequate speed is the Corona CS/DS-919MG which is already on the larger side, I use the 929 version in a 1:18 truck.
xmodcanuck I guess you might have noticed I've been absent from meets lately - I've been busy and kind of getting out of (larger scale) RC, but the Z are here to stay and I'm really excited for this TZ-4 and the Atomic chassis. For $60 I'm definitely getting one once they are restocked at HobbyKing. This IMO is what this scale needs that $200+ aftermarket chassis have been unable to become widespread.
I have a FlySky module from a TH9X radio. Just have to rig up an adapter to use it in my EX-1UR and I should be golden!
Old 2013.10.23, 06:29 PM   #15
r46
r46's Avatar
i use hitec hs55 in my losi truggy, the servo supplied in tz4 could be HXT500.
Dnano
#911 #Enzo #Lambo
Motoracer x2
02ex Hfay
02mod
03 Hfay
03 mod
03VE
F1ve
020 50t
030evo
AMZ
GL racing Rider
TZ4
reserved for
mini 96 gun5h311 Tracks and GTGs 17 2004.10.05 05:23 PM
Noble Pieze Prize For Mini Z Breakthroughs NOMOTORLIMIT Miscellaneous Discussion 0 2002.12.07 12:55 PM
