Old 2012.11.01, 02:30 PM   #1
zround
ZRound for Android update
Hi there,
There is available a new ZRound for Android update. Now all your sessions are registered in a local database.
The new main screen includes a button to access to the sessions registered (folder icon).
The sessions list looks like this
With a click you will view the lap times
With a "long" click a context menu is shown giving you these options:
- View lap times (same as short click)
- Delete selected session
- Delete ALL sessions (it will ask for confirmirmation)
And this is the session laps view. The transponder used and session date are shown on top:
Direct download from your device: http://www.zround.com/request.php?49
It needs some testing from all of you as I don't own an Android device.
Bugs report are welcome. Regards,
Jesus.
Old 2012.11.02, 05:27 AM   #2
NoBrainer
NoBrainer's Avatar
Do I need to uninstall the old one?
Well. did uninstall the old.
Downloaded the new but can't open file.
Using Android v4.1.1 on Samsung Galaxy SIII
Old 2012.11.02, 11:55 AM   #3
zround
Any error message?
It is tested on Android 2.3 (HTC Wildfire), 3.2 (Samsung Galaxy Tab 8.9) and 4.0 (emulator)
Old 2012.11.02, 01:00 PM   #4
PNracing
Send a message via AIM to PNracing Send a message via Yahoo to PNracing Send a message via Skype™ to PNracing
I using S3 4.1.1 no any problem.
http://www.pnracing.com
http://PNWC.pnracing com
DownloadPNICS ICS Android Apps for ICS Setting
PNracing is offline   Reply With Quote
Old 2012.11.02, 01:37 PM   #5
2.7RS
2.7RS's Avatar
Did you open your Gal () to accept "unnoficial" apps?
don't remember the correct word, and i'm posting from my cell at the moment.
well its "ukjente kilder" under "instillinger-applikasjoner"
2.7RS is offline   Reply With Quote
Old 2012.11.03, 11:29 AM   #6
d1nzfe
d1nzfe's Avatar
Love the new feature to view laps timing.
But why do it show only <10min timing. Anything more will not show.
Also it still hangs if connect to WIFI if you do any setting change.
d1nzfe is offline   Reply With Quote
Old 2012.11.03, 09:18 PM   #7
NoBrainer
NoBrainer's Avatar
had to install a new browser to get it to work.
it would be great if you could see the settings when you choose settings.
Old 2012.11.04, 05:05 AM   #8
zround
OK. Let me make some tests. Thanks for reporting.
It may be your previous browser blocks installers to prevent malicious software to be installed, even zround ))
I have tried to reproduce the issue about opening settings unsuccessfully. I use the system log to write down traces, could you please send me the system log?
I like to use "aLogCat" to view and send log files easily. See https://play.google.com/store/apps/d....alogcat&hl=es
Thanks in advance.
Old 2012.11.04, 03:15 PM   #9
zround
I have timed sessions for more than 10min and it works. I can't figure out why you can't see >10min. What does happen when the clock reach 10min limit in your installation? Does it stop receiving lap times? Does it disconnect?.
What I've seen is that the last lap is not saved. It is not an android app issue but ZRound race manager bug. It is solved, then new release is ready for downloading (1.12.9).
Regards.
Old 2012.11.05, 04:32 AM   #10
d1nzfe
d1nzfe's Avatar
Regards.
Oh yes, last lap is not recorded. Meaning 10mins run is recorded till 9.58.xx and last lap not recorded.
I shall try the new version.Thanks!
Old 2012.11.05, 04:45 AM   #11
NoBrainer
NoBrainer's Avatar
I can install it now when I just got me a different browser.
Installed perfect.
Now I just have to make it work with speach.
I will try it tonight again.
Old 2012.11.05, 11:06 PM   #12
Sinister_Y
Sinister_Y's Avatar
please note that I've converted the latest version to playbook format. Some good news and some bad news.
Good news is that the program is running good in almost all respects. The program announces the lap times, etc...
The bad news is that whenever you try to retrieve results from a previous session, (quick select) the program crashes. "the application ZRound (process com.zround) has stopped unexpectedly. Please try again." then a button "Force close".
This is the same case after a long select and press the "view laps" option, same message as above.
Mini-Car Club of Canada (MC3)
www minicarclubofcanada com
Old 2012.11.06, 01:37 AM   #13
tudor_47
tudor_47's Avatar
Installed perfect.
Which browser do I need to get it to install the app?
I have changed my phone so that it accepts app from unknown sources..
I have android 4.0.4
/Johnny
Get a P28
Old 2012.11.06, 04:34 AM   #14
NoBrainer
NoBrainer's Avatar
I just tried "Opera" browser.
Haven't tried any else.
Old 2012.11.06, 06:29 AM   #15
tudor_47
tudor_47's Avatar
Thanks!
I'll give that a try then.
/Johnny
Get a P28
ZRound Companion application for the BlackBerry PlayBook Sinister_Y ZRound 12 2012.11.14 11:17 AM
ZRound Suite update 1.10.10 zround ZRound 1 2011.09.14 03:06 AM
ZRound Suite update 1.10.4 zround ZRound 4 2011.02.06 05:36 AM
ZRound Suite update 1.9.8 zround ZRound 0 2010.05.08 03:15 AM
ZRound Suite 1.9 zround ZRound 10 2010.02.19 01:25 PM
