Old 2002.08.06, 12:42 PM   #1
racerdx6
Mini-Z Master
Angry gear diff problems
my gear diff is having some problems. when i flip the car upside down and spin the right wheel forward the left wheel goes the opposite direction. and it does the same thing when i spin the right wheel back. im not that dumb. i know thats correct. but when i spin the left wheel forward, there is quite a bit of resistance and the right wheel doesn't even spin. it works properly when i spin the left wheel back. should i rebuild and lube my diff or just buy a ball diff.
racerdx6 is offline   Reply With Quote
Old 2002.08.06, 12:50 PM   #2
W-tone
Cleaning the diff is not a bad idea, but you should try and play around with the tightness of your wheel nuts.
W-t
"Jazz is not dead, it just smells funny..."
W-tone is offline   Reply With Quote
Old 2002.08.06, 03:02 PM   #3
MINI-WRX
Mini-Z Instagator
MINI-WRX's Avatar
Yup, clean that sucker out, I was having the same problem, but a little worse, my car would pull really strong to the right, cause power was not being transfered equally to both wheels, but, i stripped my ball diff down, cleaned the bearing and reinstalled it, and it works great now. also do what W-tone, play with the tightness settings, that should get you up and running again.
MINI-WRX
MINI-WRX is offline   Reply With Quote
26T--->28T ball diff gear= longer gear ratio correct? pinoyboy Mini-Z AWD MA-010, MA-015 8 2007.11.05 12:45 PM
Gear Diff hpgod Mini-Z F1 MF-010, MF-015 5 2007.07.11 11:53 PM
Diff Gear Upgrade Snafu car47 Mini-Z Racer MR-02 3 2006.02.23 03:58 PM
Diff Gear Assembly Clip ltdx149 Mini-Z Overland MV-01 2 2004.12.23 01:18 PM
TopCad Ball Diff Problems! pkh Beginner Questions 1 2002.09.16 03:07 AM
