Old 2015.10.08, 10:54 AM   #1
ilove599xx
R246 MM and MML
Dear all,
Can anyone here let me know what's the difference between MM and MML motor mount in R246? also RML.
I am just guessing the "L" means low.
Thank you all
ilove599xx is offline   Reply With Quote
Old 2015.10.08, 12:19 PM   #2
is not MML the same as LM?
RML is rear mount with no top damper.
Old 2015.10.08, 08:06 PM   #3
Here is more info regarding bodies that can be used with particular motor mounts:
http://mini-z-guide.com/bodies.htm
Wheel base can be set from 86mm (S); 90mm (M); 94mm (L); 98mm (LL); 102mm (3L); and 106mm (4L)
I believe that the shortest wheelbase for the mm motor mount is 98mm...
It's been quite a while, anybody know what the shortest wheelbase for the lm motor mount is? I do know though, that they are usually being paired with lm bodies ie Porsche 926, Mazda 787, Mercedes sauber c9, and the Toyota gt1
Hope this helps
Old 2015.10.08, 08:16 PM   #4
Greetings I have a trip in November and was hoping that you could give me some information regarding Miniz shops and tracks in Taipei and Taichung... I would love to drop by and check up on the mini z scene in Taiwan.
Sorry to be off topic... pm sent...
Old 2015.10.08, 09:58 PM   #5
ilove599xx
I don't think so, I got this problem because I bought MM motor mount and MML damper system from R246 and they don't match at all. I hope that link is ok to post since that's from the orginal kyosho website about R246
https://kyoshoshop-online.com/kyosho...&cid=route_246
Old 2015.10.09, 11:11 AM   #6
imxlr8ed
imxlr8ed's Avatar
Could it be the difference between MM and LM? Because of the difference in diff widths?
http://www.howfastareyou.com
SUPPORT LBR!!!
(Local Basement Racing)
imxlr8ed is offline   Reply With Quote
Old 2015.10.09, 01:08 PM   #7
Assuming as i sugegsted MML and LM are the same thing, then yes. MM and MML/LM are different widths for the diff shaft.
Old 2015.10.09, 08:45 PM   #8
ilove599xx
I don't think MML and LM are the same thing, because there is a RML. http://kyoshoshop-online.com/kyosho/...id=r246_mini-z
and look at official cars that would fit RML from Kyosho website I don't see the relation with LM, maybe the "L" means"low"just for certain car hight? It means "LOW"?
or
MML just a motor mount for MM and LM both??
Old 2015.10.10, 06:55 AM   #9
Along that line e of this thinking, if RML is no damper, perhaps MML is similar in that it's just MM without a damper.
Old 2015.10.10, 12:32 PM   #10
ilove599xx
http://www.kyosho.com/jpn/support/in...otor_Mount.pdf
maybe Kyosho Support can help? I don't really understand through that support. Maybe you guys can understand?
Old 2015.10.10, 09:59 PM   #11
KWT
That's a MM motor mount that uses a LM diff.
Old 2015.10.11, 06:28 AM   #12
ilove599xx
so what's the benifit of it?
