Old 2015.06.05, 04:12 AM   #1
ilove599xx
R246 motor mount
R246 Mini-Z MM Aluminum Motor Mount,
I just bought that beautiful motor mount,
When I installed it to my chassis I found out I forgot to install a screw inside the mount cover, but when I tried to take the cover off it just won't come out, is there a proper way to open the motor mount cover? I tried to put some oil on and use flat screw driver to take it off nothing really worked.
by the way, my mr03 is previous using x power damper, will that match the r246 mm motor mount? I am a bit of worried for that too
Old 2015.11.20, 08:16 PM   #2
rojak
rojak's Avatar
post some picture, can't imagine.
The damper you use with which motor mount?If stock kyosho motor MM motor mount,should be no problem.
MR01->MA-020VE->MR02-VE>MB010
rojak is offline   Reply With Quote
R246 Garage in Japan 180SX SR20 Kyosho 11 2012.12.20 10:44 AM
R246 Aluminum Wheel Weights BlackBerry Parts and Hop-ups 2 2012.01.12 05:52 AM
R246 Individual dampers tastetickles Mini-Z Racer MR-03, MR-03 VE, Sports Series, EVO 11 2011.09.04 01:36 PM
R246 Balance Charger and Discharger arch2b Batteries, Chargers and Dischargers 0 2011.04.30 07:52 PM
R246 life batts/pn charger lfisminiz Batteries, Chargers and Dischargers 6 2011.02.24 05:22 AM
