Can you show a picture of the true bearing that you installed? I am wondering if it is a shielded bearing or a sealed bearing? You really do want it to be a shielded bearing with out grease in it. Put it on the shaft that it goes on and spin it. If it does not spin around a few revolutions free it has grease or dirt in it. If you have a PN bearing cleaner bottle you can put some motor spray in it to clean it out. If it is a sealed bearing you will want to get another bearing that is shielded. Hope this helps.
btw even after clearing really not even a single turn if i spin them, even with a little crc on them no spin..maybe i got a set of bad bearing..any idea of what i can buy?
If the bearings are from Kyosho then it is highly unlikely that you could purchase anything that is in fact a better product so I don't think your issue is mechanical with the product. How long did you soak the bearings in the alcohol? If overnight then I would suggest something stronger like lacquer thinner for the same overnight period. Allow them to air dry(it won't take long if using thinner) then apply a semi liberal application of WD-40(or local equivalent but WD is the best) and again allow to air dry. That "should" do the trick. It is very difficult to spin up a bearing that size with just your fingers since it lacks mass so just make sure it is positioned and seated properly and test it out. To see how free it is you should remove the pinion gear so that you are not bringing the motor into the mix. With the pinion removed the car should roll like a "Hot Wheels" car.
It roll lesser then without bearing.
can it be a coupling problem?
Maybe with bearing istalled i have too much contact beetween spur gear and differential...
The problem is that the differentian don't have possibility to be relocated and it's really firm in it's slot
Clearances are something that needs to be checked at each step in the process. Does the bearing seat properly with the spur and so on until you reach the step where it starts to bind.
Apparently yes.
if you just move the car with hand (even without pinion) you can feel more friction and the car is slower even when you use the engine...
the bearing is pretty tight on the spur gear and sit very well in the rear part of the chassis.
My only tought is that when you have all istalled: spur gear to main driveshaft, bearin in the bearing slot and chassis fully istalled you can have tension due to misalignment beetween spur and bearing...
but if this is the problem i don't know what to do...cause it can only be linked to a bearing slot badly done from kyosho
How did everything work with the stock bushing? Is it in fact the correct bearing? I have no idea if the bearing is the same for an 020 as it is for the older 010. Does Kyosho have a technical support number where you are located? You can get a lot of great info here but waning interest for the last few years has thinned the knowledge pool.
no support here...
Btw ma 020 ve arrive with full bearing..only where you see the bearing in the photo in first post here you have nothing..only an hole where spur reach rear diff.
The bearing is thw correct one..in mini z manual they write down the correct type of bearing
