Old 2017.10.23, 02:40 PM   #1
BitChar-G
Kyosho Light Kit Voltage? (MZW429R)
What voltage does this kit use? Can I give it 4.8 volts directly?
Reason being is I have an MA-020VE, the port where the light kit would normally plug into on the "Sports" chassis is used for the ICS on the "VE" chassis.
I have to wire the kit directly if I want to use it. I know I won't get the two stage braking tail light, was looking forward to that .
http://www.kyoshoamerica.com/LED-Lig...Z_p_23442.html
BitChar-G is offline   Reply With Quote
Old 2017.10.24, 05:29 PM   #2
xmodcanuck
There are other led light kits that'll work with the ics plug. Atomic has an older one with 4leds (expandable to 8leds) that for sure that does (I have it). They also have a newer (more expensive) version with 9leds and a programmable board.
I think Eagle also has one, not sure how that one plugs in though. There's also a r246 light kit which looks to have an ics plug.
And I think there's one made by gtpower that might work, but not 100% sure.
There are options that'll get you the dim/bright headlights/brake lights that you're looking for.
Old 2017.10.24, 11:44 PM   #3
BitChar-G
I'm guessing these all have external boards to process data coming out of the ICS connector and translate that data for the lights?
Reason I liked Kyosho's kit is it simply plugs in for power, everything is done internally.
Though the functioning brake lights are cool, I can do without it. I'm going to try and figure out if the pin out of the ICS socket or Gyro socket can directly power the kit, would just have to rewire the kit if so.
Will look into the kits you mentioned, good to know that kind of data comes out of the ICS socket in real time.
Kyosho Stock Class Racing arch2b Washington DC Area GTG, MD/VA/DC 59 2019.12.23 05:46 PM
Xmod light kit for Z FD? Skv012a Mini-Z Science 2 2008.12.10 01:22 PM
XMod light kit modified for Mini Z? CoconutSport Mini-Z Science 12 2004.01.15 02:07 PM
Ferrari 360 Modena Silver for SALE! w/ Light Kit & A-BB MazdaSpeedRX-7 Miscellaneous Discussion 11 2003.04.30 05:34 PM
Kyosho Led Light set?? Wedginator Beginner Questions 0 2002.01.08 02:03 PM
