Old 2017.01.19, 09:34 AM   #1
NYCislander
Kyosho Mini Z AWDvs2WD wheels?
Hi everyone,
I was trying to compare the AWD wheels vs the 2WD wheels for a Kyosho Mini Z? Does anyone have photos of both so I could see the difference. I am thinking it is the middle of the wheel.?
Thank you for everyones help and passion for Mini Z
NYCislander is offline   Reply With Quote
Old 2017.01.19, 12:08 PM   #2
yes, the inner hub differs. AWD are slotted whereas 2WD are not.
Old 2017.01.19, 01:21 PM   #3
2wd has holes for the bearing in the center, awd has a small slot for the axle. They are not interchangeable.
Also, take note to the offset of the wheel, different bodies require different offsets. Too large, and you will have wheels sticking out past the body, which could lead to damage of the chassis and binding/rubbing of the wheel on the body.
Old 2017.02.05, 08:12 PM   #4
NYCislander
Great thanks for the help
Thank you for the help I wanted to post pictures just to make sure!
http://imgur.com/a/EMKiM
Route 241 Raceway at Kyosho Tim Johnson Route 241 Raceway, Lake Forest CA 399 2015.01.13 02:49 PM
shop.tinyrc.com: Holiday Savings Start Today & End In 2014! Mrs Mini-Z Newsletters 0 2013.11.27 09:33 AM
FS: 1/24 RC Kyosho Mini Z NASCAR RTR sets with batteries and Tx Mini-Me-Zee Mini-Z Marketplace 5 2013.11.24 05:21 PM
FS: 3 built AM MR-02 chassis with entire accessory collection builthatch Mini-Z Marketplace 10 2010.03.08 08:08 PM
Kyosho Aluminum Monster Wheels Desmo Mini-Z Monster MM-01 8 2005.05.16 08:13 PM
