Old 2015.12.07, 04:25 PM   #1
Ancient Artist
Ancient Artist's Avatar
MR03 Double A-Arm Wide Front Conversion Kit
Can someone (Phillip?/Grant?) tell me what's different on the Wide Front end vs. the standard PN MR03 Double A-Arm kit?
http://www.kenonhobby.com/PN-Racing-Mini-Z-MR03-Double-A-Arm-Wide-Front-Conversion-Kit-Orange_p_45574.html
The description is as follows:
Specs:
This conversion kit for MR3050 Double A-Arm to m wide each side.
Includes:
Wide Upper Bracket
Wide Lower Bracket
Tie Rod 0
Tie Rod +1
Tie Rod +2
Tie Rod -1
Tie Rod -2
Requires for complete:
MR3050, MR3050C, MR2056F, MR3050K, MR3050D, MR2503, MR2504, MR2505, MR2509, MR3050L, MR2506, MR2507, MR3050U
I have a Double A-Arm now, so what would be the minimal parts would I need to convert mine if I wanted to?
Is this different than the new MR3062 Upper Bracket?
Are all the tie rods in the conversion the same lengths as the standard kit? (I'm guessing not if this is wider but wanted to ask to make sure)
Also-
Can I get some insight on what advantage/disadvantage does this provide vs. the standard Double A-Arm suspension.
I apologize for the long post but I'm a bit confused and can't seem to figure it out.
Any help would be appreciated.
Ancient Artist is offline   Reply With Quote
Old 2015.12.08, 12:41 AM   #2
yasuji
PN RacingTEAM Driver
yasuji's Avatar
Send a message via AIM to yasuji Send a message via Yahoo to yasuji
Specs:
Includes:
Wide Upper Bracket
Wide Lower Bracket
Tie Rod 0
Tie Rod +1
Tie Rod +2
Tie Rod -1
Tie Rod -2
Also-
If u have a AA ARM set up currently u will only need the wide conversion kit making it over all 2mm (1mm on each side) .. Wider including longer toe bars to match... allowing the ability to run less offset front wheels.... Reducing the amount of front wheel "scrub"
Grant "Yasuji" Matsushima
www.pnracing.com
gm@pnracing.com
yasuji is offline   Reply With Quote
Old 2015.12.08, 01:47 AM   #3
talk about details coming down to a few couple of millimeters for a racing advantage...
Old 2015.12.29, 12:38 AM   #4
Ancient Artist
Thanks for the clarity!
Much appreciated...
PN Racing Mini-Z MR03 Pro Front Lower Arm Set NARROW LED Parts and Hop-ups 6 2011.11.29 04:28 PM
98mm Conversion kit?? Mazda787b Mini-Z AWD MA-010, MA-015 57 2006.07.06 03:07 PM
gpm front lowering kit West.F1 Parts and Hop-ups 0 2002.09.20 11:17 AM
Going wide in tha front Slonik Setups 4 2002.09.10 06:13 AM
Front Knuckle Arm Eddie69 Parts and Hop-ups 4 2002.01.24 11:52 AM
