I've feen finding that on one of my MR-03s it will somewhat randomly kill the throttle when I hit a rail. I switch it off and on and no throttle. Steering still works fine. Sometimes a few power cycles gets the throttle to come back. Currently it's completely dead and I can't get throttle back at all. What could be causing this? Again - steering works fine.
Mike Downey | blog
Supporting Kyosho America | Peak Racing | KO Propo America | Fast Pace Racing
mine have done the same a few times. but i have always found it to just be the motor wires not secured well on the board. they would be as tight as you could get them but still not good enough. now all my motor wires are soldered to the board and have had no issues since.
PN Racing
R1Wurks
LET's Go Racing
DG Designs
Make sure the batteries are secure in the clips. I pry-out the negative tabs on the battery tray clips to make sure there's good pressure on the cells when in the chassis. Try also using a non-modded side batt clips (With both top-chassis hinge joints attached, not cut like the MR02 batt clips we use to mod); Also, put a piece of tape on the underside of the battery clipsso that when you clip the clips on they push hard against the cells to keep 'em in place. Try this andd lmk if the problem still persists dvs
__________________ *** TOP SECRET MOTORS *** [FONT="Book Antiqua"]
