Old 2002.09.05, 01:02 PM   #1
Incubusions
Send a message via AIM to Incubusions
Where can i get treaded tires for my mini z in the USA
I need treaded tires and a new longer antenna for my mini z, also i have been looking for the covering (sheath) that i have seen on alot of peoples minis that go around the antennna. I have a huge problem of my mini z losing signal after about 25-30 ft and then it just goes crazy and in turn hits a wall or something. also it cant grip the tiled floor here cause of the stock slicks. if anyone can point me in the direction of these products and where i can order them from, id be very gracious
Incubusions is offline   Reply With Quote
Old 2002.09.05, 01:24 PM   #2
Breeze
Mini-Z Pro
Tower Hobbies has some GPM treaded tires. Two types,I believe.
You can use heat shrink tubing over your antenna. Ck in the
MZR shop here. As in all other R/C, Z's are suseptible to interference. Ck that your antenna connection is tight. You can also make a longer antenna out of piano wire. Or add a length of
wire to the existing antenna wire that connects to the PCB. Loosley coil it, then connect it to the antenna. Ck Dracs site for
some more ideas. Welcome to the forums.
ZYAL8R
ck out my website
SpiceyCajun.com
Breeze is offline   Reply With Quote
Old 2002.09.05, 01:52 PM   #3
Incubusions
thank you, any links to tower hobbies, or dracs site?
Old 2002.09.05, 02:01 PM   #4
Breeze
Mini-Z Pro
Here's Dracs- http://draconious.net. and you will have to type in ************ as this site link is censored here-competition
w/the MZR shop you know.
ck out my website
SpiceyCajun.com
Old 2002.09.05, 05:36 PM   #5
Incubusions
i looked for GPM products on ************, and i couldnt find any gpm products, maybe i need a lil more guidance
Old 2002.09.05, 05:51 PM   #6
Breeze
Mini-Z Pro
My bad-They are made by Megatech. To see all of the products
that Tower carries-from the home page go to advanced search and put in mini-z/ all manufacturers/ all products.
ck out my website
SpiceyCajun.com
Old 2002.09.05, 06:43 PM   #7
racerdx6
Mini-Z Master
for yer antenna just get the mini-zracer.com insulated antenna. for yer tires. if you want some for the tile i think that the pit shimizus (i probaly spelled it wrong) 15 degree tires from the shop.
racerdx6 is offline   Reply With Quote
Noble Pieze Prize For Mini Z Breakthroughs NOMOTORLIMIT Miscellaneous Discussion 0 2002.12.07 12:55 PM
on my mini z the tires on the right side are looser than the left left side. mini Z modifier Beginner Questions 4 2002.08.02 09:42 AM
