Old 2005.09.27, 02:35 PM   #1
waikk
need help !!! steering problem.
Hi, I just bought a new firelap2.0. My problem is when i turn on the car (after turn on the controller), the steering turn to the right. I try adjust the steering to the center using the steering trim (maximum trim) but it still a bit off from the center. Anyone has any ideas how i can fix the problem. Appreciate all the helps you guys can give me. Thanks in advance.
waikk is offline   Reply With Quote
Old 2005.09.29, 12:31 PM   #2
PaulBoth
Last Place
PaulBoth's Avatar
Send a message via MSN to PaulBoth
On the top of the PCB, there is an adjustment pot that you can turn. Center the steering on your transmitter, and then gently adjust this pot until your wheel's are straight. Be carefuly though, it's very sensitive... That worked for me on my MR02 just recently.
PB
PaulBoth is offline   Reply With Quote
Old 2005.09.29, 12:38 PM   #3
700club
this should help
http://www.minizcanada.com/tech/radio.php#steeringpot
700club is offline   Reply With Quote
Old 2005.09.30, 01:42 PM   #4
waikk
Thanks for your reply. I try it already. Althrough now my wheel is center, the left and right steer is out of alignment. I tried to fine tune it so many time but still fail. Do u thing the "steering sensor" is the one that giving me problem?
Old 2005.09.30, 03:18 PM   #5
700club
sounds as though you are having similar problems that i had with my iwaver. see if this thread helps.
http://www.mini-zracer.com/forums/sh...ad.php?t=19453
Old 2005.10.01, 02:02 AM   #6
waikk
Thanks a lot for the tips. I will give it a try.
2.4GHz Steering problem rcmorris 2.4GHz ASF System (Auto Selected Frequency) 3 2008.08.10 10:13 AM
Crazy steering problem please help Eric M Mini-Z AWD MA-010, MA-015 10 2006.10.18 04:53 AM
MM02 steering problem pyro147 Beginner Questions 6 2006.03.29 02:54 AM
gpm steering parts problem marlboro Mini-Z Overland MV-01 1 2004.06.29 07:27 PM
Straight steering problem Maxfield Mini-Z F1 MF-010, MF-015 0 2004.05.26 05:07 PM
