Old 2006.11.23, 01:52 PM   #1
jbenthobbies
Steering problem
I had to put a new main chassis on my awd and when I when to turn it on the steering slamed to one side. How do I fix the problem and how did it happend?
jbenthobbies is offline   Reply With Quote
Old 2006.11.23, 06:55 PM   #2
Ninja
Mechanic
Ninja's Avatar
sounds like you broke one of the little servo wires, or the potentiometer is in wrong.
Real Racers Do It Sideways.
Old 2006.11.23, 07:24 PM   #3
Spoon
DCGTG FET Guy
Spoon's Avatar
If the wires are okay, you shoudl check the connection between the servo gears and the steering POT. I had the same thing happen when I left out the little brass washer in the MR02 servo gear assembly. If the first servo gear (the one touching the POT) does not mesh 100% and the POT does not mesh against the backplate, you will have the problem you describe.
Good luck and report back if you figure it out.
Old 2006.11.23, 10:32 PM   #4
builthatch
yes, it's a boxer
builthatch's Avatar
ugh that damn washer....
Reflex Racing :thumbup:
Old 2006.11.23, 10:45 PM   #5
Ninja
Mechanic
Ninja's Avatar
I second that, I have lost so many of these
Old 2006.11.24, 09:30 PM   #6
machine
learning the hard way
machine's Avatar
why aren't the washers available in packs of 10? Ever time i clean out the servo box i'm looking for that little thing.
[Western Canada's Mini Rc Home[/URL]
machine is offline   Reply With Quote
Old 2006.11.24, 11:58 PM   #7
builthatch
yes, it's a boxer
builthatch's Avatar
simple! that would be too simple and cost-effective for the end user!
Old 2006.11.26, 01:10 PM   #8
HighFreq
Wich washer? where is it placed. Now i have a doubt i didn't see it and lost it since my servo seems to have a lot more play since i took it out to replace the frame.
Anyone has an exploded view of where it is placed? I looked over at my AWD instructions and there is no washer in the servo from the exploded view of it.
Corrado
HighFreq is offline   Reply With Quote
2.4GHz Steering problem rcmorris 2.4GHz ASF System (Auto Selected Frequency) 3 2008.08.10 10:13 AM
Crazy steering problem please help Eric M Mini-Z AWD MA-010, MA-015 10 2006.10.18 04:53 AM
MM02 steering problem pyro147 Beginner Questions 6 2006.03.29 02:54 AM
gpm steering parts problem marlboro Mini-Z Overland MV-01 1 2004.06.29 07:27 PM
Straight steering problem Maxfield Mini-Z F1 MF-010, MF-015 0 2004.05.26 05:07 PM
