Old 2013.07.20, 05:41 PM   #1
citysurfer101a
Exclamation MR02 EX steering problem
Hi
Have run my MR02 EX car into a wall. No damage to body but now steering does not work. It is locked to the right. The steering controller allows a flicker movement to the right with a "buzz" but no sound or response the other way. interestingly the steering trim controls make a "buzz" both ways but the steering does not adjust. Any ideas ?
Thanks
citysurfer101a is offline   Reply With Quote
Old 2013.07.20, 08:06 PM   #2
greetings and welcome to the forums… try opening up the chassis and check the servo gears, from your description i suspect servo gear damage... its an easy fix... hope this helps
Tags
steering problem
steering problem MR02 Ex citysurfer101a Kyosho 4 2013.08.01 11:40 AM
Intermittent steering problem TheRinger Mini-Z Racer MR-03, MR-03 VE, Sports Series, EVO 10 2013.05.23 05:39 PM
Mini-z-monstertruck steering problem G.G.Hammond Beginner Questions 2 2009.11.17 05:11 PM
Steering bias problem with a EX-10 Helios NewbieRacer Transmitters, Receivers and Crystals 3 2009.09.25 08:50 PM
MR01-1.5 Front vs MR02 Front effect on steering Draconious Mini-Z Science 7 2006.05.13 11:47 AM
