Old 2018.02.09, 04:20 PM   #1
honda3
rcp questions
When RCP is referring to 50cm tiles that is each individual tile correct? Is the wide and and mini 96 generally 2 tiles wide? Also can a track be built off the wide expansion kit, or is just meant to build of an existing track?
honda3 is offline   Reply With Quote
Old 2018.02.09, 10:03 PM   #2
Thorvald
Thorvald's Avatar
(Please correct me if I'm wrong)
RCP comes in 50cm tiles and 30cm tiles. Mini-96 is the smaller 30cm tiles. Yes each tile is either 50cm square or 30cm square. As far as I know you CANNOT connect a 50cm to a 30cm or vice versa.
All RCP of a specific size (50 or 30) connects to each other so you can start with any kit you want. But obviously some of the kits are "just a turn" or similar.
It's best to start with a Wide-L or a pair of Wide-L's and then add an Oval etc. Two Wide-L's will let you make quite a few of the "HFAY" track layouts.
Old 2018.02.10, 01:25 AM   #3
SuperFly
bitPimp
SuperFly's Avatar
I think two Wide L sets will let you make ALL the HFAY tracks. I thought that was one of the parameters.
I think the wide expansion set you're talking about is only blank tiles and straight rail edges, and doesn't include corners or the inner corner nubs. It's made for making most sections of a wide L set 3 tiles wide instead of 2.
mini-z gallery
PDX Mini-Z
Bringing back an idea to the table for RCP to go Carpet OPtion :) Felix2010 RCP Tracks 6 2011.06.26 09:59 PM
AWD on RCP, and questions Apie Mini-Z AWD MA-010, MA-015 24 2010.01.28 12:54 AM
shop.tinyrc.com - On the MZR Forums & RCP International Shipping Mrs Mini-Z Newsletters 0 2010.01.08 03:43 PM
RCP Pin System...And some other questions USATorque55 Tracks and GTGs 0 2004.05.22 06:43 PM
