Old 2014.12.08, 02:46 PM   #1
Mania
Tri Damper plate question
I didn't want to revive the 3 year old tri damper thread, so I am posting my question here:
I am currently running the MR2994C tri damper setup for 94mm with the MR2995 motor mount, MR2161 dual spring center shock, and MR2061 disc damper.
However, I would like to try running this setup in 98mm. From what I can tell, the only new part I would need is this, the MR3399G damper plate, correct? It appears to be very similar as the damper plate I am using, except it has an extra set of holes allowing me to set the motor pod further away. It also looks like if I use the inner set of mounting holes I can also use the plate at 94mm. Can anyone confirm this for me?
http://www.kenonhobby.com/PN-Racing-...k_p_45474.html
Alternatively, would this Reflex Racing plate RX1168 work in the same way? I am using the PN racing dual spring center shock and I am uncertain if that will fit properly, as well as allowing me to use both a 94mm and a 98mm (PN-based) tri shock setup.
Mania is offline   Reply With Quote
Old 2014.12.08, 05:18 PM   #2
yasuji
PN RacingTEAM Driver
yasuji's Avatar
With the 2 top pictures every thing is there to run 94/98 set up94 is the forward position and 98 would be the rear position the same for the dual shock
Grant "Yasuji" Matsushima
www.pnracing.com
gm@pnracing.com
Old 2014.12.08, 09:54 PM   #3
Mania
Oh, sorry my bad but this is the plate I am currently using, not the one in that picture.
Old 2014.12.09, 07:46 PM   #4
yasuji
yasuji's Avatar
This is what u will need
www.pnracing.com
gm@pnracing.com
Old 2014.12.09, 09:04 PM   #5
Mania
Thanks! I see there is now a picture in the product page too - that's good!
Thickness of damper plate? NoBrainer Beginner Questions 0 2012.01.24 04:27 PM
New pn 94mm motor- Does it fit the atm ssg 94mm damper plate system erixxst Parts and Hop-ups 6 2008.08.28 03:30 PM
Atomic 94 MM MM MM & Damper plate? Mocoloco Parts and Hop-ups 12 2006.08.10 09:01 AM
Atomic Damper Plate System Fusion Mini-Z Racer MR-02 3 2006.01.11 02:13 PM
main damper and damper plate system PINCIR Mini-Z Racer MR-02 10 2005.09.23 04:06 PM
