Old 2020.01.27, 08:28 PM   #1
dc6287
Wheel question?
I have a couple m03 rwd Porscheís and want new wheels. The specs say 1.5 offset, but I donít see a pn wheel with that offset!! HELP!!!
dc6287 is offline   Reply With Quote
Old 2020.01.28, 07:28 AM   #2
+1.5mm wide? There are a large number of design to select from in this offset. If -1.5mm, there may not be any. -1mm is generally the most negative offset you will find.
Old 2020.01.28, 09:08 AM   #3
dc6287
It is +1.5, just not seeing any pn wheels with that offset
Old 2020.01.28, 10:23 AM   #4
Apologies, PN offsets are whole 1mm increments. Kyosho R246 however does make wheels in .5mm increments. Atomic S6 wheels are also available in .5mm increments.
Old 2020.01.28, 11:09 PM   #5
The 991 Porsche GT3 uses 1.5N/1W wheels on the narrow chassis. It can get away with a 2N front. I have seen plenty run 0N on the wide front end, which is equivalent to 2.5N.
Atomic S6 wheels may be hard to come by these days, they are discontinued for quite some time. The front are 19mm diameter vs the standard 20mm, which is something that I prefer for narrow bodies, or ones that offer limited clearance.
stupid wheel offset question ilove599xx Beginner Questions 10 2015.02.14 10:39 PM
Wheel offset question Mania Beginner Questions 3 2014.10.11 05:04 PM
EX-1 UR wheel sticktion? Tjay Transmitters, Receivers and Crystals 3 2008.08.18 05:43 PM
Tire and wheel set question! philophob Beginner Questions 8 2008.03.13 01:07 PM
wheel nut question stguest Beginner Questions 6 2007.06.25 11:27 AM
