Old 2009.10.08, 04:54 PM   #1
tokeco
Any other 2.4Ghz transmitters for Mini-Z
New to 2.4GHz transmitters - and have noticed a huge price difference between the KT-18 and the more high end radios (Helios)..
Any suggestions on an intermediate option that would work with the Mini-Z's?
tokeco is offline   Reply With Quote
Old 2009.10.09, 05:19 AM   #2
not sure... but can anybody confirm if you can use the ko propo EX-5 UR 2.4GHz with the mini-z?
Old 2009.10.09, 11:00 AM   #3
tokeco
It looks like the KO-PROPOEX 1UR 2.4GHz with Mini-Z Module should work, the question is now whether you can store the settings of multiple Mini-Z with this transmitter? or Do I ended up having the same problem as I currently have with the KT-18. If anyone knows please advice.
Thanks
Old 2009.10.09, 12:04 PM   #4
mikedw
The Ex5 does not work with a Z and the Ex1ur has a 30 model memory.
mikedw is offline   Reply With Quote
Old 2009.10.09, 05:38 PM   #5
Pierro
Hello!
The EX-1UR is definitely worth the money. I use it and like it much than the helios.
Much simple, 30 memory for models, module of the Helios do work without any problem and the EX-10 is a little bigger than the EX-1. So, the EX-1 fit better in my case.
Pierro is offline   Reply With Quote
Transmitters 101? Action B Transmitters, Receivers and Crystals 10 2010.02.13 06:09 AM
Signal problem with my RF901-SM Mini-Z 2.4ghz module for Helios Felix2010 KO PROPO 6 2008.12.19 01:02 PM
Kyosho Mini-Z MR-02 LM 2.4GHz ASF Pre-Order arch2b Mini-ZRacer.com Announcements 0 2008.01.20 06:02 PM
New for 2008: MR02LM and 2.4Ghz Radio System mini-z Mini-ZRacer.com Announcements 0 2007.10.16 06:24 PM
