Old 2002.02.27, 09:01 AM   #1
Chezedog
Chezedog's Avatar
Send a message via AIM to Chezedog
Ball Diff Ball Diff Ball Diff Ball Diff II
Could use any and all advice or tips about the adjustment of a Kyosho ball diff in an F1 car.
-Chezedog
Chezedog is offline   Reply With Quote
Old 2002.02.27, 02:40 PM   #2
CoolHandLuke
Send a message via AIM to CoolHandLuke Send a message via Yahoo to CoolHandLuke
The adjustments on it are simply tighter or looser. Tighter gives it more traction, looser allows the diff to slip a little for better control in the corners so you don't just spin out. I don't have one but me and jenkij47 have tested his a bit. It's kinda hard to tell much difference. The car either spins the tires taking off or when you loosen it up, it slips the diff a bit so the tires don't spin.
I think jenkij47 just tighten his up to where there was very little diff slip and called it good. I think I would too. One things for sure...It sounds better then the stock diff!
CoolHandLuke is offline   Reply With Quote
Ball diff changes... HaCo Mini-Z Racer MR-02 4 2007.07.15 03:26 PM
PN Ball Diff vs. Kyosho Ball diff briankstan Mini-Z Racer MR-02 15 2006.08.15 06:54 PM
ball diff help signal21 Parts and Hop-ups 14 2006.04.16 02:20 AM
Ball diff problem bobman Parts and Hop-ups 15 2002.03.01 09:32 PM
Ball Diff Ball Diff Ball Diff Chezedog Off-Topic 37 2002.02.11 12:12 PM
