Old 2003.12.17, 02:21 PM   #1
pedrolf
Mini-Z Novice
Questions , questions , questions , help!!!
Hi all , Im askin these questions to see if all you can give me the final push into gettin my X5 overland Mini-z...
* by diminishing length and width of chassis...can I fit a racer body to the overland chassis?
*Ive heard that the PN SO1, SO2, SO3 motors and faster than the XSpeed..Can you fit these motors to the OVerland?
* What are Servo Savers?...FETīs?....FET Chips?
* Do all overland cars have the same chassis?...Is there a strongest car in the overlands?
*How do Mini-z Racers perform on rugs , and asphalt?....How about the Overlands?
* Are there plenty of Overland hop-ups available....Are there hop-ups available enough to not make the Overland a useless purchase?
Thanks.
PEDROLF
pedrolf is offline   Reply With Quote
Old 2003.12.17, 02:35 PM   #2
PAULANGELO
Mini -Z Mutilator
PAULANGELO's Avatar
let me give it a try
no, they are different enough to make it not worth while.
Yes they can altough you will need either the internal or external turbo. I have had problems with the external turbo in my OL and when ready, I will be doing the internal one again.
* What are Servo Savers?...FETīs?....FET Chips? Servo savers is actually a spring mechinisim between the steering plat and the servo gear. this takes the tension off the gear so that the teeth do not break during crashes. The FETS are the electronic chips that help regulate the current that goes to the motor.
the chassis are the same but have different settings for the wheel length. I hear the older bodies are stronger than the new ones but I have the X5 and love it.
The racers run best on flat/smooth surfaces. the OL's are more versital and can be run on thicker carpets and even in hard packed dirt.
There is enough with hopups and homemade customizing that the OL's are NOT a useless purchase. I have 2, my son is getting one and I am looking for another deal to get a 3rd.
Hope this helps and welcome
PAULANGELO is offline   Reply With Quote
Pit gear questions marc Atomic 7 2008.10.09 09:02 AM
Questions... gun5h311 Mini-Z Racer MR-02 6 2004.10.09 03:46 PM
To Mr. NML...I have a couple questions RedRSX Motor Tech 4 2004.03.26 06:50 PM
Rally Car Questions...Help!!!! =D pedrolf Off-Topic 3 2003.12.13 08:26 PM
Copyright Đ2011 Mini-ZRacer.com
