Old 2006.02.23, 03:56 PM   #1
car47
Fresh Meat
car47's Avatar
Send a message via AIM to car47
Diff Gear Upgrade Snafu
Hey folks!
So I bought the Delrin pinion and diff gears, and ceramic diff balls, and am trying to install on my 3Racing ball diff.
No Luck - seems like the delrin gear is too thick; or not extruded the same way as the plastic gear on the ball diff; plus the ceramic balls are too big to fit into the 3racing gear.
Anybody know what I'm talkin' abooot?
I'd love to know if there's just some different bits I could get to surround the gear that'll fit right, or if I'm supposed to drill out the delrin gear myself, or if I'm just an idiot and bought the wrong upgrade parts.
TIA y'all
car47 is offline   Reply With Quote
Old 2006.02.23, 04:34 PM   #2
briankstan
SLMZ / HFAY
briankstan's Avatar
each company has a slightly different gear on the diff and the design is different. Some have 1/16, 3/32 & 1/8" balls in them. the motor pinions are universal though.
you will need to get the specific parts for the diff you have. I would go by brand and then look for the correct size.
Old 2006.02.23, 04:40 PM   #3
Mojar7070
Racer4Life
Mojar7070's Avatar
Which diff did you buy for MR-01 or MR-02??
As briankstan already mention each company has a different design for the diff. You have to know which parts are replaceable for the diff or have lots of knowledge for which parts are interchangable.
-My Gallery of Cars-
Mojar7070 is offline   Reply With Quote
Old 2006.02.23, 04:58 PM   #4
car47
Fresh Meat
car47's Avatar
Well, It's a 3Racing Diff, and 3Racing gear / pinion set. So that's why I'm surprised that none of it is fitting together.
argh.
Atomic ball diff gear running loud dameetz Parts and Hop-ups 12 2008.05.02 12:18 AM
26T--->28T ball diff gear= longer gear ratio correct? pinoyboy Mini-Z AWD MA-010, MA-015 8 2007.11.05 01:45 PM
Gear Diff hpgod Mini-Z F1 MF-010, MF-015 5 2007.07.12 12:53 AM
Diff Gear Assembly Clip ltdx149 Mini-Z Overland MV-01 2 2004.12.23 02:18 PM
Help again, trying to mesh pinion gear w/ diff gear!!! walds11 Beginner Questions 2 2003.06.11 05:06 PM
