Old 2007.06.23, 02:33 PM   #1
stguest
wheel nut question
Hi guys. Can someone tell me why the right rear wheel nut on my mini-z won't come off? It seems to just spin and spin and spin but won't come off. I've tried holding onto everything but the wheel nut so that nothing will turn but the wheel nut itself but that doesn't seem to help. Anybody know what I'm doing wrong? Thanks.
stguest is offline   Reply With Quote
Old 2007.06.23, 02:41 PM   #2
Spoon
DCGTG FET Guy
Spoon's Avatar
Is it an MR01 or MR02? maybe that doesn't actually matter.
Take off the knuckle and see if the axle is spinning inside of the plastic housing. The axle is glued or pressed in and sometimes that bond will slip so it's just spinning inside of the plastic. Remove the knuckle and you;ll have a better idea of what's going on.
Old 2007.06.23, 05:06 PM   #3
byebye
byebye's Avatar
If you have both wheels on and take that one off first you shouldn't have any problems. It could also be stripped but you should keep both wheels on and planted on the work surface.
Kris
Old 2007.06.23, 10:00 PM   #4
Spoon
DCGTG FET Guy
Spoon's Avatar
ByeBye is right. I missed the rear part.
Old 2007.06.25, 09:11 AM   #5
stguest
I tried keeping both wheels on and loosening the right rear wheel nut first but that didn't seem to help. It just spins. Does this mean that my wheel nut is stipped? Is there anything I can do if it is? Thanks for your help with this.
Old 2007.06.25, 09:33 AM   #6
Spoon
DCGTG FET Guy
Spoon's Avatar
Is it a stock black plastic one?
It sounds like the wheel nut might be stripped. You can get some alloy wheelnuts. They have a nylon insert and work much better. I would recommend Kyosho or Atomic.
As far as getting the current wheel nut off, see if you can pinch it with some pliers and pull it off or at least compress it enough that the plastic will bite on the threads and maybe unscrew.
Old 2007.06.25, 10:27 AM   #7
HammerZ
Master of Thrash
HammerZ's Avatar
My guess is somethings stripped. The right wheel on the gear side, from looking at the rear with the chassis right side up. It will spin inside the wheel, hold the left rear tire as you turn the nut. If that don't work try to pull on the tire wheel (away from the gear) on the left as you turn the nut. With plastic wheels just be careful and not twist the wheel at an angle, it can crack the hub.
Tire and wheel set question! philophob Beginner Questions 8 2008.03.13 12:07 PM
IW02 - Urgent help needed - Threaded wheel nut Joefullager iWaver 4 2006.05.30 06:31 AM
What size of nut driver for 2mm wheel nuts??? matrix Parts and Hop-ups 3 2004.06.03 11:08 PM
I need a wheel nut! Just One! squeegee Miscellaneous Discussion 7 2003.09.18 08:44 PM
Alloy wheel nut probs Scoobaru Beginner Questions 12 2002.02.08 05:37 PM
