Old 2019.08.03, 12:09 PM   #1
PN 93-102mm Multi Motor Mount
What damper is best fit for this motor mount at 102mm setup?
Old 2019.08.03, 10:14 PM   #2
The damper position does not change with the wheelbase. I believe it stays in the shortest position (94mm MM), don't have the mount to check.
Old 2019.08.03, 11:31 PM   #3
Which damper kit though? Does that mean any of the PN disc dampers will work?
Old 2019.08.04, 12:08 AM   #4
PN damper does 94/98 MM, it will work. Basically any PN ML type damper plate, or atomic 94mm if what I see in the low resolution pic on their site is correct.
Old 2019.08.08, 05:40 PM   #5
SuperFly
bitPimp
SuperFly's Avatar
So if you are running a disc damper, do you still have to fly the tri-shock CF wing on that mount, or is there a simpler way to attach it?
I'm looking for a new MM pod, with my primary use likely to be 98mm, but I do like the possibility of 102LM. Trying to decide between this and the LCG v5 mount.
mini-z gallery
PDX Mini-Z
Old 2019.08.08, 05:45 PM   #6
I was hoping to order the PN disk damper. It doesn't state it's 102mm capable specifically with mount I have. I do have the tri-damper cross bar that comes with the mount.
Old 2019.08.08, 09:06 PM   #7
SuperFly
bitPimp
SuperFly's Avatar
This looks like the damper plate designed to work with that mount. It kind of looks just like all the other 98mm disc damper plates, except two holes for the side dampers. Even though is says 98mm, from what I've gathered, it's only the rear axle position moves to change from 98 to 102. The T-plate and disc damper maintain the same position. That seems to be the selling point of that mount: that you can change the motor and the wheelbase without touching the T-plate or damper.
mini-z gallery
PDX Mini-Z
Old 2019.08.09, 06:20 AM   #8
Thanks. I don’t run 102mm much, if at all. It seems I build a 102mm every couple years only to run it and sell it. There are some races coming up that are specific to 102mm and curious to put some of my painted C9’s back on the track.
PN Racing Multi Offset Aero Dish Set starkweather Mini-Z AWD MA-010, MA-015 2 2012.09.09 02:08 PM
102mm wheelbase pros/cons ? redneckracer Beginner Questions 12 2010.10.21 05:41 AM
Kyosho multi offset wheel package: what offsets? RobinZ Parts and Hop-ups 1 2008.02.05 12:52 PM
Kyosho Volks Racing Multi Offset Wheel Sets arch2b Parts and Hop-ups 2 2007.10.13 04:00 PM
102mm wheelbase bodies gulfclk Parts and Hop-ups 0 2006.07.28 02:55 PM
