Old 2011.10.19, 05:49 PM   #1
Tapir
Guest
Posts: n/a
Front end chatter
Can anyone explain this?
If I use grippy front tires. X15's etc, my front end chatters quite a lot. Dampening seems to have no effect on the chatter.
Grip is good, but I think the chattering takes away speed. It doesnt sound good either
The tires are glued, trued etc, and no folding is happening.
Any ideas?
Old 2011.10.19, 05:58 PM   #2
unearthed name
Which part of the tire you glued? The middle part or the side wall?
unearthed name is offline   Reply With Quote
Old 2011.10.19, 06:29 PM   #3
Mike Keely
Are you running the stock frontend on the car or using anyones aftermarket front end parts? Are you able to take a picture of the frontend and post it?
DG-Designs / Brooklyn Hobbies
Old 2011.10.20, 10:19 AM   #4
Tapir
Guest
Posts: n/a
The tires are secured with R246 tape.
Sometimes I glue, sometimes i use this tape.
As for front end, I am using a reverse king pin setup.
Will try to get pictures later.
I have quite a lot of preload on it.
Old 2011.10.20, 03:00 PM   #5
lfisminiz
lfisminiz's Avatar
I know on the PN reverse king pin set-up i have, I like the soft springs. Usually blue. Orange is softer yet. Hard springs dont work for me.
Old 2011.10.20, 03:07 PM   #6
color01
color01's Avatar
That could be part of it -- when I run reverse kingpin, I use soft springs and zero preload. I make sure there's zero preload and zero droop when the car is sitting on the ground with batteries and body, this tends to give me the best baseline setup to work with.
Brian Ma
Greyscale RC
PN Racing | My TinyRC Blog
Old 2011.10.20, 05:09 PM   #7
Mike Keely
+1 I agree
Old 2011.10.21, 02:59 AM   #8
themelis factor
PN RACING TEAM DRIVER
themelis factor's Avatar
Talking
Chattering sometimes occurs when there is too much rear traction. Try using a harder rear tire or try using the PN tri shock system. By running the tri shock setup it will help you corner faster and should eliminate frontend chatter.
Johnny Themelis
PN RACING
MAJ'S HOBBY SHOP
THEMELIS FACTOR RACING CELLS (TFR)
themelis factor is offline   Reply With Quote
Old 2011.10.26, 04:38 PM   #9
Tapir
Guest
Posts: n/a
Less preload and softer springs helped. Thanks a lot.
Regarding tri shock mentioned. Does only the PN work?
Old 2011.10.27, 07:45 AM   #10
color01
color01's Avatar
PN and Reflex are both good -- Reflex's is lighter and smaller but I prefer the PN one for its longer damper tubes (holds more oil). But that's only for rear end chatter problems -- if your front end is chattering then you must address the front end setup, and vice versa.
Brian Ma
Greyscale RC
Old 2011.10.27, 08:43 AM   #11
Atomic-USA
Customer/dealer support
Try lubing your kingpin or adding some camber.
www.rcatomic.com
Atomic-USA is offline   Reply With Quote
front steering servo chatter lornecherry Mini-Z Racer MR-03, MR-03 VE, Sports Series, EVO 3 2011.01.05 12:54 AM
FS: Reflex Racing Wide Track Front End Old Crow Mini-Z Marketplace 3 2009.08.03 04:47 PM
Hmmm.. Binding inthe front end. Need Help (pics) ryno Mini-Z Monster MM-01 6 2005.10.17 08:25 PM
