Old 2009.01.15, 12:52 AM   #1
Skv012a
Skv012a's Avatar
Bone Stock Supra + New Mounting System
Here's my latest brew- a new lego mounting system that nor adds weight when not in use nor interferes with Kyosho clip slots. It can be as simple or as elaborate as you want; can lead to virtually any point in the upper area of the body; can be used to mount ballasts or act as a reinforcement frame.
Supra itself will be further stripped of stock (beat up) paint to look new and I'll repaint the windows black/dark blue/green/etc and panel line this sucker.
Front clip was made out of styrene and Kyosho cement. Body-side mount point was glued using the same stuff and 2-3 pieces of .5mm styrene to lower the rear end enough to allow fancier body kits later on.
New site.
Old 2009.01.15, 04:55 AM   #2
Bryson
Thats a very good idea of using lego!
Do a tutorial, for AWD too.
Bryson is offline   Reply With Quote
Old 2009.01.15, 12:06 PM   #3
Skv012a
Skv012a's Avatar
Pix are essentially a tutorial- I've taken them to clearly show how I did it.
New site.
Old 2009.01.15, 07:34 PM   #4
mini-z
Administrator
mini-z's Avatar
Whoa, my two favorite things, Zs and LEGO, combined!
Old 2009.01.15, 08:02 PM   #5
okoye
Guest
Posts: n/a
my baby :'( NOOOOOO
Old 2009.01.15, 09:58 PM   #6
Skv012a
Skv012a's Avatar
I'll make her better, stronger- I have the technology.
New site.
Old 2009.01.16, 02:09 AM   #7
Interesting concept, however, the added weight is too high. I dont know how well it will hold up in collisions either.
Old 2009.01.18, 07:46 PM   #8
Skv012a
Skv012a's Avatar
Not that well, but in terms of a fully functional, easy to make, show car mount its solid.
New site.
Old 2009.01.19, 03:31 AM   #9
Bryson
What brand is this cover?
I dont find any in KYOSHO.
Old 2009.01.19, 03:50 AM   #10
HammerZ
Master of Thrash
HammerZ's Avatar
It's an Xmods body. that's a different way of doing this I guess. The nose clip I used a heat and bend method instead of gluing to parts together. This way a shot to the wall don't break the glue joint. For the sides I carved out some T bar stock to fit. I guess the legos you can always lift up the body.
How much clearance do you have with the rear motor mount? On mine I cut away the orignal body lock mount to allow the mount to move free.
I used the Camaro body for mine, also found the front of the battery boxes hit some parts under the body. A little more carving was done there. The Supra looks to clear that ok. I noticed you removed the rear hood screws?
Tags
body, lego, supra, toyota, xmods
Best all around Stock Motor to use without Fet upgrade Warchild Motor Tech 37 2005.11.07 08:33 AM
A new Stock Car class will be starting this fall at CP Mini RC Raceway Blackno3 CP Mini RC Raceway, NY 58 2004.10.27 08:23 PM
WANTED: au Cerumo Toyota Supra Stock Wheel Set arch2b Miscellaneous Discussion 0 2004.01.26 06:26 PM
remote and stock parts for sale BoyWonder Miscellaneous Discussion 0 2003.03.10 08:02 PM
Stock Class Racing DAMZer Off-Topic 13 2002.08.29 04:57 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
