Old 2018.08.17, 10:35 PM   #16
mugler
mugler's Avatar
Yes in our case I was thinking of keeping the disk choices to kyosho only to a) keep close to as box stock nature of the class & b) limit the choices as much as possible again staying as close as possible to the box stock theme. (spec by default kinda thing)
Tires, t-plate, bearing, springs, lubes & fluids are open to any brand though. Speaking of lube some 300to500-ish CST lube under the MM2 damper disk (94mm) made my car handle noticeably better.
Also i have feeling FWD in box stock format with only tires and right gearing can keep up with RWDs and they all should be run together...I'll be testing that idea in upcoming months.
Old 2018.08.18, 09:52 PM   #17
I think layout design will have a lot to play in fwd performance relative to rwd. Gearing will play a major role as well. I think fwd could work better for those 90mm bodies that rwd needs to use an rm config
Old 2019.07.01, 06:40 AM   #18
This may have been addressed before but do the FHSS boards have power to the ICS port for transponders/lights and such? I know the FHS do not. I’m rebuilding the club loaner fleet and will need to get transponders wired up for FHSS RWD RTR’s and want to know if I need to order more ring terminals or ICS cables?
Old 2019.07.01, 11:00 PM   #19
I believe that both sports and RWD do have power from the port, but it is a different pinout than ASF. I would opt for the eyelets...
Old 2019.07.02, 06:17 AM   #20
That would make sense, just need to find the pin out. Pre-wired terminals are dirt cheap and easy enough to re-pin. It’s much easier to re-pin a terminal than carry a bunch of ICS terminals and ring terminals to keep the club stocked if possible. I’ve not found a similarly cheap source for ring terminal leads.
Old 2019.07.02, 07:34 AM   #21
That makes sense.
Did some digging on rctech, looks like the voltage on the fuss port delivers 4.75v vs the evo and asf at 5.75v.... which means that there must be a voltage booster in the ICS electronics of some sort (don't think the user was using lipo). It was stated that ilap transponders did not work on the fhss port, light flashed intermittently.
https://www.rctech.net/forum/showpos...postcount=4012
I would wire one up, and give it a test run.
https://www.rctech.net/forum/showpos...postcount=3995
Old 2019.07.02, 08:26 AM   #22
I can confirm I-Lap transponder does not work on FHSS (FWD) ICS port however if pin-out is different, I had not tried altering the pin-out.
Old 2019.07.06, 05:08 PM   #23
Has anyone deciphered the power pin out for FHSS ICS port? I need to figure out how to do this as there is no readily available power taps on the FWD in particular.
MR03 sports series motor selection flashdaniels Mini-Z Racer MR-03, MR-03 VE, Sports Series, EVO 21 2015.11.12 01:04 PM
MR-03 Sports Series Board Swap byebye Mini-Z Racer MR-03, MR-03 VE, Sports Series, EVO 6 2014.07.29 11:01 AM
Kyosho Mini-Z 2nd Generation Book marc Miscellaneous Discussion 32 2012.12.23 02:47 AM
March 26, 2011 - Reflex Racing Series Mike Keely The Track, Gaithersburg MD 13 2011.03.27 08:24 PM
MC3/ Reflex Racing Points Series info Sinister_Y MC3, Toronto, ON, Canada 0 2011.01.26 09:03 PM
