Old 2019.10.29, 07:56 AM   #1
LJH
Bearing Sizes?
Hello All,
I have had a number of bearings go bad in my MR03 and wanted to order some more replacements. Before I started looking at bearings I measured what I have and the fronts measure 2X6X2.3mm. I then started looking around and on the Boca site they have two sizes listed 2X6X2.3 and 2X6X2.5mm. To make it more complicated I posted this questions on another site and was told that the 2.5mm width was what I should go with so now I am wondering what the correct size is.
Thanks.
Cheers,
Jim
LJH is offline   Reply With Quote
Old 2019.10.29, 12:01 PM   #2
mugler
mugler's Avatar
The correct bearing size is 2x6x2.5 ( not 2.3 width)
The three bearing sizes used on Mini-Z's are:
2x6x2.5 - front wheels / also can be used on the rear left wheel instead of plastic bushing.
3x6x2.5 - rear axle/outer diff housing/ rear right wheel.
4x7x2 - PN style spur center bearing
If you come across an ultra thin Reflex Racing Spur (discontinued) they require a 4x7x2.5 center bearing
Old 2019.10.29, 12:32 PM   #3
LJH
Gracias.....Wonder where the 2.3mm bearings came from? As I take front wheels on and off I will check they to make sure I have all the same size bearings on the inside of the wheels.
Cheers,
Jim
Diff tips thread EMU Mini-Z F1 MF-010, MF-015 7 2016.12.09 06:29 PM
Muchmore Bearing Removal Tool rocketman Miscellaneous Discussion 16 2009.11.17 12:41 PM
Motor bearing sizes and availability? ianc Motor Tech 2 2009.02.04 10:20 AM
xmod bearing sizes k_bojar Mini RC 9 2006.03.15 05:19 PM
Motor Ball Bearing Questions ? T_G Motor Tech 6 2002.04.30 11:38 PM
