Old 2015.12.07, 04:08 PM   #1
RFick73
N.E.R.D.
RFick73's Avatar
Question Which DPS/Damper setup are you running?
Hey gang,
I am looking to fix up the back end of my stock 98mm chassis.
Currently I am running the stock Motor pod & using an older 98mm Atomic Alum DPS plate & disc. There is no springs on the disks as they simply don't fit it without binding up the system nor is there a top spring as I am unable to mount one in due to the missing front part that it would need.
What is everyone running these days? I looked around and strangely found limited options.
I like the one on my Mod class, but the parts were from someone else & I couldn't hunt them down on Atomic, EGR or Kenon.
I believe Derek has been playing with a new Tri-Damper setup.
Any thoughts or suggestions would be greatly appreciated.
Here is my current Stock setup:
& Here is my current Mod setup:
-=MR-03: VE-Eco (Stock) 98mm Pearl Yellow Lamborghini Murcielago LP670-4 SV | VE (Mod) 98mm Yellow Ferrari 458 Italia GT2=-
MA-020 AWD VE Custom Nissan GT-R GT500 2008=-
F1 Jordon Honda EJ11 2001 Jarno Trulli "Bitten Heroes" #12=-
*EX-6R*
Website: BC Mini-Z Club
RFick73 is offline   Reply With Quote
Old 2015.12.07, 05:36 PM   #2
cowboysir
You'd be hard pressed to figure out a tri-shock system for the stock motor pod.
From what I can see you need to lift the damper plate off the chassis and get a longer damper post so you can use springs/damper grease.
I can look around in my bag of tricks for some way of lifting the damper plate and if I can make the 20th we can build something up.
my custom body album...
Old 2015.12.07, 11:14 PM   #3
RFick73
N.E.R.D.
RFick73's Avatar
Originally Posted by cowboysir View Post
From what I can see you need to lift the damper plate off the chassis and get a longer damper post so you can use springs/damper grease..
I think I gave away my last longer damper posts. But I do have the following stuff. I have other tidbits & stock pieces that I can make use of as well.
I can order what ever I may need to make it work.
*EX-6R*
Old 2015.12.08, 08:17 AM   #4
cowboysir
The spacer in the middle might be a good start to get the lift you need.
The other problem I forsee is that the damper plate design is firing you into a wiring scenario that interferes with a top shock placement.
You may want to look at a full kit from PN. It'd have all you need to get good space, fitment and able you to change wiring to get that K shock in the photo on board. I don't have a shock on all my cars but the ones that have it work well. I'll text you a photo of my best performing set up.
Old 2015.12.08, 09:27 PM   #5
TeeSquared
Redline
The setup you are using on your mod car is the standard 98 mm disk setup from Kyosho: http://www kenonhobby com/Kyosho-Min...t_p_45078.html
But the friction plates look to be atomic.
I've had really good luck with the Kyosho disk damper. I use it with Ruby Lube, which gives nice consistent damping along with the Kyosho oil shock, which I see you using already.
Here is my setup on my mod car:
And on my stock car:
Brian's RCX 2011 Final Setup color01 Mini-Z Racer MR-03, MR-03 VE, Sports Series, EVO 35 2017.02.19 06:38 PM
FS: 2.4GHZ MR-02 Mini-Z Ready-to-Race Setup w/Lots of Extras Slpnbyu Mini-Z Marketplace 3 2010.12.19 03:09 PM
MR-02 RM Stock Racing Setup Spoon Mini-Z Racer MR-02 19 2006.05.10 05:13 PM
Mini-Z setup question..... UNITED_RC Setups 4 2006.03.27 11:06 AM
Couch Racing track setup - 2 ovals plus turns for sale Ryan Gardner Miscellaneous Discussion 0 2005.03.31 04:01 PM
