Old 2005.03.30, 11:23 PM   #1
Dustin
Steroids are Legal in R/C
Dustin's Avatar
Fet question that has not been answered yet
I serched all over these forums to try to find the answer to this question but it must not be on here. The simple question is this.
If i ran 2 of the same exact cars but one with 3x2 fet stack and the other with a completly stock PCB which will run longer.
Would a car with just single replacment fets run longer.
I ques that the fet upgrade car would run longer becouse the fets are more efficent. But they also have more power output.
Thanks for the time.
Special thanks to Surge Worldwide and Intigy for their continued support in this hobby.
For the best AAA racing batteries, contact me.
Dustin Richards
CEO
Ripped Racing Products
Dustin is offline   Reply With Quote
Old 2005.03.31, 12:37 AM   #2
Pippoe
Pippoe's Avatar
The FET-Stack has lower internal resistance, thus allowing your motor to drain more current, which will discharge your batteries faster. Runtime also depends on the motor, pinion and mechanical resistance.
Cheers
Pippoe
Pippoe is offline   Reply With Quote
Old 2005.03.31, 01:15 AM   #3
LBRC
Providing you go the same speed a 2x3 FET stacks would allow the car to run longer too.
Good old ohms law can be used to explain why the lower resistance will allow more current to travel through the circuit and a higher voltage to the motor.
What it doesn’t explain is power loss. Simply put; a resistor, or device with resistance, is a heater and not a very efficient one at that. So a lower on-state resistance means less power lost due to heat. And even better it’s a two for one deal, since less heat is being generated by the FETs they stay cooler and their resistance stays lower. Unlike a single FET that has a higher resistance which generates more heat which in turn can raise its resistance in a vicious circle.
But these benefits are limited, although the closer to the edge of extinction you push the FETs the more noticeable the benefits become. With a stock motor the increase in speed, torque, and runtime are barely noticeable if at all, especially run time because the FETs shouldn’t be generating much heat (very little power loss). But when you add a motor that pushes the current limit and causes the FETs to get nice and toasty your batteries have to start paying that heating bill.
Providing of course the FETs you used had a lower on-state resistance and where installed correctly with no static damage, heat damage, cold solder joints, etc.
LBRC is offline   Reply With Quote
Old 2005.04.01, 12:35 AM   #4
NOMOTORLIMIT
nomotorlimit@hotmail.com
NOMOTORLIMIT's Avatar
There was one thread placed by minizmodifier back in the days regarding fet upgrades. He got his car up to 50 mph, with an XSPEED!
http://www reflexracing net
Old 2005.04.01, 12:31 PM   #5
demick1
demick1's Avatar
The difference will pretty much be negligible. As was pointed out, the fet stack will be more efficient - which will have fewer power losses - which would indicate that you would get a longer run time. But as was also mentioned, the gain in efficiency will also allow the motor to draw more current, thus shortening the battery life.
Either way, the differences aren't significant enough to care about. There is likely more variation between motors (two x-speed motors are not exactly alike) than the difference we are talking about here.
Demick
demick1 is offline   Reply With Quote
Steering FET blown - Replacement Question PridgeoK Beginner Questions 2 2008.04.17 02:39 PM
Fet question for fet-techs? xxam Mini-Z Science 2 2008.04.03 09:48 AM
Mini-z steering FET Question (read this ByeBye) CUSTOM Miscellaneous Discussion 6 2007.10.08 09:38 PM
Question about the stock fet aimfox Mini-Z AWD MA-010, MA-015 2 2007.08.30 06:29 PM
burnt fet question BoyWonder Parts and Hop-ups 8 2003.07.16 11:38 PM
