2005.07.22, 09:43 PM
Does any one really break in?
Does any one really break in their motors? I have read a few of the old threads of suggestions of how to break them in, but really, are you guys breaking in the motors? If so, which method have you found to be the best overall - especially for stock motors?
Thanks for satisfying my curitosity!
PD2
2005.07.22, 10:24 PM
i typically run all new motor on one cell till it dies. that's all i do and if it really help, i couldn't tell.
2005.07.22, 10:43 PM
r/c user
If you are going to bother to brake it in be sure to water dip it for a few minutes at 3volts.
2005.07.23, 12:02 AM
Team ShoBoi
Yes, break in is needed when motor is new or new brushes is installed to seat the brushes. Break in using 2 cells for 3 minutes with a fan blowing on the motor.
2005.07.23, 12:29 AM
Pet Human
Who needs a fan if the motor is underwater?
2005.07.23, 08:38 AM
See this is what I'm talking about - everyone seems to have their own version of break in.
Back when I ran electric off-road, we broke in motors using comm drops and break in stand. I was going to use the same method, but then I started reading all these different ways to break in. I know the method I used for doing 540 cans was better just because I had tried various things. It appears with these mini motors that it really does not matter which method you use - not one is better than the other - just so long as you break it in.
Thanks for the feedback guys! Really appreciated!
PD2
2005.07.23, 06:17 PM
Master of My Mini Domain
That's how I do it with Mini-Z motors as well. I run it on two cells for maybe ten minutes and every now and then hit it with a comm drop. I use bushing oil on it while doing this. I think it does make a difference as the motors seem a bit faster at least for a while vs just using them straight out of the box, but it may just be luck of the draw or my imagination. Without a dyno there's really know way to know for sure.
David
2005.07.23, 06:24 PM
Run Motor at 3 volts for 2 minutes in water, then 3 minutes in air at 1 volt, then stand on your head and spin around while running it at 1.5 volts... then dance a rain dance for more water, and run it for another 5 minutes at 2 volts under water again..
LOL
I just buy them toss them on the car, and go...
2005.07.24, 01:30 AM
MINI-Z MONSTER GARAGE
Geez.....sounds like the Hokey Pokey
MR02RM, MR02MM, MZM,
Pro-Pulse Pro T-100 1/18 4X4,
2005.07.24, 10:22 AM
Pet Human
It's easier for me to let the cats "bat" a motor around for a while before putting it in a Z.
2005.07.24, 10:46 PM
Truth is, why go through the hassel of breaking it in when you are not raceing? The true reason of breaking in motors is this:
In the stock class Z racing only X-speed can be used. Sooo...people buy like 10 of them, break them in and pick the fastest one hopeing to win
I still ran mine for like 10 minuits at 3 volts to be safe lol!
2005.07.25, 02:53 AM
I tried a water breaking for like half an hour? Not a too bright......Needless to say the brushes are nearly gone. What I did though was water breakin at 3 volts. Took the motor apart and cleaned the comm with a pencil eraser till it was nice and shiney. Put a drop of oil on both bearings and put the can back together. It ran smooth and very quiet. I would say it helps. If your bored and don't have a track and all of your stuff then do it. I think your are just as good to go if you run it on 2 cells till they die.
-Byebye
2005.07.25, 01:39 PM
PD2:
I race with you over in Houston, I think you know who I am. I have never broke in a motor. You've seen my car and how the motor runs. From that you can draw your own conclusion.
2005.07.25, 02:11 PM
Originally Posted by Q ball
PD2:
Thanks man! I appreciate it! I know who you are - was waiting for your counterpart to reply to, but did not see him reply yet. No worries - I'll take it that he does it that way too.
Thanks for the reply!
PD2
