Old 2007.01.20, 11:33 AM   #1
SaiTam
Are you Fetted?
SaiTam's Avatar
Can these MR02 boards be saved? PICS
I am pretty good at unsoldering and soldering FETs. However, I got two damaged boards from a fellow racer. One or more pads are missing on these boards. How can these boards be saved?
Board 1: Two missing pads on the motor side
http://mini-zracer.com/mini-zgallery...0/Img_5922.jpg
Board 2: One missing pad on the reverse FET (Inner)
http://mini-zracer.com/mini-zgallery...0/Img_5921.jpg
Any input is appreciated.
Old 2007.01.20, 11:46 AM   #2
homestar21
is sleepy.
Send a message via AIM to homestar21 Send a message via Yahoo to homestar21
it takes a lot of skill to work with pads. I can solder and unsolder, but I can't really work with pads.
homestar21 is offline   Reply With Quote
Old 2007.01.20, 11:59 AM   #3
MINIz guy11
Hibernation ON!
Send a message via AIM to MINIz guy11 Send a message via MSN to MINIz guy11 Send a message via Yahoo to MINIz guy11
The missing pad on the motor side can be fixed with a aftermarket turbo. I would say to get a nelly for it but since they are not being made, get a spider. For the Spider, all you need are all of the inner FET pads.
Airtronics M8 | MR-02 | F1 | MR-015 | Overland 'Evo Nellied' | MR-02 Pan Car
MINIz guy11 is offline   Reply With Quote
Old 2007.01.20, 12:43 PM   #4
Draconious
Draconious's Avatar
solder the fet on normaly, but solder a jumper from the leg with out a pad... to the nearest solderable area the pad would have connected too.
Ive done it before... as long as that is ALL that is wrong with it, it will work again.
Old 2007.01.20, 04:36 PM   #5
nivlacs3z
GSR #222
Send a message via AIM to nivlacs3z
You can repair both of those. For the pads that are on the out side you could use a nelly or a spider, or you can solder on fets and have a wire connecting the out side onto the motor pad. For the one with the inner damaged pad you'll need to expose the wire leading to the pad and solder to that. I'll anything that you don't wana fix, so thats always another option. ^_^ GL man
nivlacs3z is offline   Reply With Quote
Old 2007.01.20, 11:28 PM   #6
imxlr8ed
imxlr8ed's Avatar
The output side is no problem... all those feet can be connected, even on turbos. I usually put a fat wad of solder on the back of my turbo stacks. The one on the forward side might be a little trickier, but I've done a few of them in the past.
http://www.howfastareyou.com
SUPPORT LBR!!!
(Local Basement Racing)
Pics of my MR02 chassi--MustangGT Thomas P Chassis 8 2007.10.15 10:52 PM
86mm MR02 Martini and 934 Porsche (PICS) SaiTam Mini-Z Racer MR-02 57 2007.03.15 01:42 PM
Pics of My MR02 MM NSX Big_L Chassis 22 2006.04.16 02:20 AM
Land Cruiser on MR02 (pics) bennyfizzle Mini-Z Racer MR-02 17 2005.02.06 01:38 PM
mr-01 difference novadk Beginner Questions 7 2004.08.22 12:14 PM
