Old 2007.03.20, 10:40 AM   #1
schluerfi1978
Newbie question: Which rims for Lego tires on OL?
Hello together,
I just got an OL a few days ago and wanted to do a body lift plus mounting larger tires. I would like to use the Lego 30.4 x 14 tires, but I`m still unsure which are the correct rims to mount these tires. Here in the forum, it always says "racer rims". However, as for racer rims, you can get MR-01, MR-015 and MR-02 rims. So, which of these are the correct rims for the Lego tires?
Greets,
Michael
schluerfi1978 is offline   Reply With Quote
Old 2007.03.20, 03:34 PM   #2
jimbo
Mini-Z n00b
i think you can mount them on the stock rims but they will be like rounded or better way to say not fit properly and the racer rims i think are the wide rims 11 mm or something like that.
Jim
jimbo is offline   Reply With Quote
Old 2007.03.20, 04:13 PM   #3
hrdrvr
hrdrvr's Avatar
Originally Posted by schluerfi1978
Hello together,
Greets,
Michael
It is my understanding that the 'racer rims' are a reference to any of the wheels that come on 2wd drive cars. Im unsure about the 01s, but the 02 and 015 accept the same wheels. I would assume that those are the wheels people are talking about as they are the most common and easiest to find.
Landon
LET's Go Racing!
Old 2007.03.20, 05:42 PM   #4
byebye
byebye's Avatar
I was using 11mm wide rear wheels with a 0 offset.
The problem you run in to is if the wheels are too big they will hit the wheels well so you'll have to experiment with different offsets. I do believe that I was using wide with 0 offset.
With the Lego tires you also have to cut that hump out of the center of the lego tire.
Those are BMW wide rear wheels with lego tires.
-Byebye
Old 2007.03.22, 03:53 PM   #5
MiniZMaster
Team Nomadio 007
MiniZMaster's Avatar
Send a message via AIM to MiniZMaster
wow looks nice.
Current trucks:
2 xxx-t's,minibaja,overland,mr-02,mini quake,ft tc3
MiniZMaster is offline   Reply With Quote
Another newbie question - Greasing rear diff jb23fan Beginner Questions 4 2004.10.17 11:10 AM
FOR SALE Square rims with foam tires sc0627 Miscellaneous Discussion 6 2003.03.10 05:44 PM
tires lifting from rims laminaleigh Parts and Hop-ups 9 2002.08.21 07:54 PM
Question about tires? orbmij Beginner Questions 3 2002.02.09 02:46 AM
Audi TT and GPM rims w/foam tires Kevin Parts and Hop-ups 2 2001.12.04 08:44 PM
