Old 2007.04.06, 10:03 PM   #1
jbevins
Send a message via AIM to jbevins Send a message via Yahoo to jbevins
AWD wheel offsets
I was windering if someone could direct me to the list of offsets for AWD I saw it once but now I can't find it, or I just need the offset for a 575gtc for an AWD
jbevins is offline   Reply With Quote
Old 2007.04.06, 10:24 PM   #2
Ninja
Mechanic
Ninja's Avatar
there isnt an offset wheel wide enough for the 575GTC on the AWD. You would need +5.5N for the front, and +3N is the widest front they make. Then again, you could run +2.5W on the front, and +3W on the rear. That would be the correct width, just have to find a wide tire combo that works with the wide front tire.
Real Racers Do It Sideways.
Old 2007.04.06, 10:49 PM   #3
jbevins
I have the widest fronts from 3racing which is a +3N and it defintely needs to be wider, I guess I will put on some +3.5 since that is the widest I'm going to be able to find, thanks
Old 2007.04.07, 09:30 PM   #4
jbevins
I was looking around and can't find what I'm looking for, been searching for a while!
what's the widest offset narrow rims that anyone makes? the widest I've found was +3.5
Old 2007.04.07, 09:57 PM   #5
Ninja
Mechanic
Ninja's Avatar
that is the widest anyone makes.
Old 2007.04.07, 10:44 PM   #6
TheRinger
THATS HOW I ROLL
TheRinger's Avatar
+3.5N fronts is the widest anyone makes at the moment. I'm running +3.5N fronts and +3W rear with the 575gtc body and they work well.
Old 2007.04.08, 02:29 AM   #7
3.5N/3.0W is the widest offset you should need to run on the 575GTC, any wider is kind of rediculous. When I was running the 575GTC on an MR02 I used 1N/3W which is the same track width in the front. Any more offset on the front made the car very sluggish in the corners.
Old 2007.04.08, 08:30 AM   #8
that is exactly what i will be running on my 360 gtc on an mr-02. i just have to buy the +1 front wheels as +2 rubs rails too much.
ccson is running the 360 gtc on the awd so he would be able to tell you what works well for him if interested
Old 2007.04.08, 03:07 PM   #9
The 360 (and GTC) should use +1N/2W maximum. I think that the 2W rears need a little shaving of the body to clear. I used to use C5R rear wheels (1.7W) which were perfect, until I broke one. Right now I am using +1N/1W on my 360 MR02. On the AWD I would use +2.5N/1W though.
AWD wheel offsets for the Blue Fairlady case aimfox Mini-Z AWD MA-010, MA-015 2 2007.08.06 11:09 AM
Kyosho AWD Aluminum Wheel Set question.. doongas Mini-Z AWD MA-010, MA-015 2 2006.08.11 05:56 PM
official kyosho awd product description herman Mini-Z AWD MA-010, MA-015 16 2005.09.30 10:18 PM
Kyosho Announces AWD Mini-Z! mini-z Mini-ZRacer.com Announcements 0 2005.08.25 01:24 PM
