Old 2012.01.02, 09:36 PM   #31
pomme de terre
pomme de terre's Avatar
Ditto to what everyone said.
You can't go wrong starting with the 599xx. One of the fastest guys at MC3 runs it as well. And like pzchuky said, chances are you will end up experimenting with different bodies down the road anyways, so don't worry too much.
By the way, the night you drove my car I was running the 360GTC at 96mm, not 98mm. I change things up depending on the layout and what's working. I also switch between +1 and +1.5 offset sometimes, depending on what wheels I happen to have tires mounted on (I'm lazy ).
pomme de terre is offline   Reply With Quote
New Grave Digger Style Monster Body RTR DogbreathRacing Mini-Z Monster MM-01 38 2005.12.31 09:40 AM
Grave Digger Body???? DogbreathRacing Custom Bodies 4 2005.02.22 02:36 AM
Late Model Modified Wedge Body DogbreathRacing Custom Bodies 18 2004.12.20 03:43 AM
Easy Body Lift, Run Swampers DogbreathRacing Mini-Z Overland MV-01 9 2004.01.21 08:05 PM
A Tight Fitting Body... Corvette Draconious Custom Bodies 0 2001.11.26 12:43 PM
