Old 2002.08.07, 06:31 AM   #1
PITZON
MR 02 Driver
PITZON's Avatar
Send a message via ICQ to PITZON
Adjustable Camber
Saw this one too.. Some kind of kit fron Squat so you can adjust the camber-angle on your Z..
Looks interesting, have anyone tried this?
Micke Pitzon....
Check out some of my cars http://mini-zracer com/gallery/pitzon
PITZON is offline
Old 2002.08.07, 06:37 AM   #2
jeffrey
undisputed
jeffrey's Avatar
Send a message via AIM to jeffrey
looks confusing
FASTEST NON-TURBO RACER!
I DON'T NEED A FAST MOTOR TO GO FAST!
jeffrey is offline
Old 2002.08.07, 07:21 AM   #3
butler
Mini-Z Chief
butler's Avatar
Send a message via MSN to butler
Cool. I have been looking for one if those.
Gives less understeer and a bit more room under the arches of the body shell.
Haynes Manual: Prise away plastic locating pegs...
Reality: Snap off...
Haynes Manual: Lightly...
Reality: Start off lightly and build up till the veins on your forehead are throbbing then re-check the manual because this can not be 'lightly' what you are doing now.
butler is offline
Old 2002.08.07, 02:02 PM   #4
PITZON
MR 02 Driver
PITZON's Avatar
The best thing ust be that you can have different camber depending on how much of your tires you have worn out.. There use to be insane grip in the beginning and then after a while the grip tends to be less...
Then it would be nice to EASY adjust this whitout changing the knuckels...
Micke Pitzon....
PITZON is offline
Old 2002.08.07, 10:09 PM   #5
Strider-
Strider-'s Avatar
Aiya
we've all mistaken........
foolish me, never read the package..............
its CASTER, not camber
Strider- is offline
Old 2002.08.07, 10:24 PM   #6
The Thunderer
The Thunderer's Avatar
Well, now that THAT is settled....
Uhh, what's a caster? What's an adjustable caster? LOL.
"Its the least I can do for the Captain of the Enterprise."
"Where there is lightning, there is The Thunderer."
The Thunderer is offline
Old 2002.08.07, 10:28 PM   #7
Strider-
Strider-'s Avatar
Caster is adjusting the angle of the kingpin in this case....
so it looks like / or \ from the side
Strider- is offline
Old 2002.08.08, 03:02 AM   #8
mini-z
Administrator
mini-z's Avatar
These are on their way...
mini-z is offline
Old 2002.08.08, 03:10 AM   #9
jeffrey
undisputed
jeffrey's Avatar
how does adjusting the caster help?
When I watch F1 races I notice that the front tires are slightly angled but how does It help?
jeffrey is offline
Old 2002.08.08, 06:03 AM   #10
butler
Mini-Z Chief
butler's Avatar
Camber tilts the kingpins in towards each other.
Castor tilts them back. Castor gives you increasing camber has the steering moves.
Castor is better because it doesn't wear the tires unevenly, it only applies camber when you need it in the corners and not all the time.
butler is offline
Old 2002.08.15, 11:24 AM   #11
PITZON
MR 02 Driver
PITZON's Avatar
Got my hands on the Castor Kit today, looks quite cool and High-Tech
What the poor description on "Japanese" says i have no clue about but iŽll see if i can get it together...
I got a decal sheet from Square who looks just awesome to.. Around 400 small decals of various famous brands.....
Im happy today
Micke Pitzon....
PITZON is offline
Old 2002.08.15, 11:42 AM   #12
Ken Mifune
2-Z or not 2-Z...
Ken Mifune's Avatar
Dragster gear
Although it should help the front grip better (oversteer), increasing the castor will slow down your steering response but it'll help for straights and high speed runs.
Ken Mifune is offline
Old 2002.08.15, 04:28 PM   #13
ultrawide
Same same, but different.
Foto from the hobby show (by Shin)
ultrawide is offline
Old 2002.08.23, 01:30 PM   #14
PITZON
MR 02 Driver
PITZON's Avatar
Maybe im very stupid but i cant get the caster-kit to fit properly, Im not satisfied with the mounting at all...
If someone can translate the text who are on the package i would be very happy.. Its written in a language i dont understand and there are no pictures in the instruction... Just a scrappy pic of it already mounted on a car
Micke Pitzon....
PITZON is offline
Old 2002.08.23, 01:52 PM   #15
PITZON
MR 02 Driver
PITZON's Avatar
Maybe someone have installed this kit and can be able to post some instruction or so...
Micke Pitzon....
PITZON is offline
what is camber and caster? herman Setups 1 2008.03.27 10:38 PM
Wtb Caster Bar (top, Bottom, Or Both) Jebroni Mini-Z Marketplace 1 2008.03.19 10:26 AM
Caster Nightcargo Mini-Z Racer MR-02 6 2008.01.17 07:34 PM
Caster, how much is too much? Vagabond Setups 4 2003.04.03 11:41 PM
squat 3 deg caster kit Ko Racer Parts and Hop-ups 4 2002.12.08 05:06 PM
