2008.10.17, 03:35 PM
Do you want to go fasst??
RV Project AM 27MHz Micro Fine-Tune Esc Unit (4WD) miniboard
Hi
I am having a very good offer on a brand new in box RV Project AM 27MHz Micro Fine-Tune Esc Unit (4WD) miniboard, which I am planning to use with a WoahNelly or a Black Widow Spider.
Q: Other than the Fine-Tune port adjustment, which I guess wont need due to the fact I’m using an Ko Propo Helios Tx and can do all my fine tunes thru it. Is there any mayor performance differences between this RV Project AM 27MHz Micro Fine-Tune Esc Unit (4WD) miniboard and the original Kyosho AWD Miniboard unit???
Thx in advance for the info .
Cheers.
2008.10.17, 03:45 PM
Mercedes Benz AMG as opposed to Hugo
2008.10.19, 03:39 PM
Hi mleemor60,
Long time don’t talk with ya
Thxxx for the info, I was worried do to the price it is been offered even that the person is selling it to me has to chassis and both with this miniboard. I lookup on the Internet and it goes for only @ $48.
Since I only gotten a answer from you, I think not many people have experienced it.
Again thxxx…
Cheers
2008.10.19, 06:15 PM
at the Bleeding Edge
ive used this board,lots of punch as it has 8898 fets!!
the solder joints are a bit iffy but once re-done the board performs well
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Bleeding Edge Racing UK
2008.10.19, 08:03 PM
Hi mk2 and thx for the comment.
So the only problems with this R/C Unit miniboard are the wires?
That’s no problem, it is my custom to swap the bad quality original servo and motor wires for micro hobby servo wires (white, red, black) and the main power wires for 18g superflex silicone cover wires in order to improve conductivity. The micro hobby servo wires (white, red, black) are made with more filaments and better covered material plus very thin and flexible too, they provide better signal to the pot and more energy to the servo motor. Regarding the antenna wire, I swap the original short one for a longer one-piece Futaba FM antenna wire to achieve an incredible better signal.
About the Fine-Tune port adjustment, since I have no use for it, can I remove it (de-solder)? I have a Helios Tx in which I can fine tune to my needs.
Mk2 I intend to swap the FETs for a WoahNelly or a Black Widow Spider, I am thinking more on the Spider B-W for it’s size, since it’s only 14x11mm. Any observation here?
Cheers.
2008.10.19, 08:46 PM
the wires that are fitted are fine,its the solder joints are not that good and break off very easy(dry joints)
you can de solder the ics plug easily with some solder braid.
nelly will handle more abuse,spider is smaller but has less power handling in my experience
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
2008.10.19, 09:02 PM
mk2,
Do you recomend the "EVO Nelly Tubo"?
The have other options Nelly at their www
Do you know the size in "mm"?
I guess the intalation is as you sugested for the 2.4Gz board right?
Thxxxx
Cheers
2008.10.19, 09:47 PM
evo nelly is the one,but you can no longer buy it from the site,second hand is the only option
im going to say around 20mmx20mm(i can measure mine when im home)
yes its the same wiring as on the 2.4/AD boards
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
2008.10.19, 09:59 PM
Perfect
I think ausmicro has them too, I'll check it.
Thx man
Cheers
2008.10.20, 11:12 AM
Hi mk2
I just received a note from EGR Mart confirming that they will do FETs 4562s stacking service if I buy the RV Project AM 27MHz Micro Fine-Tune Esc Unit (4WD) miniboard from them, (which by the way is only $5 more than the offered one from a friend) EGR is asking for the 4562 stacking configuration I want, would you recommend 1x1 on bottom side of the RV Project PCB and 2x2 on top ?
Would this configuration be the same as a 2x3 on a regular AM PCB ?
I couldn’t find the Nelly and the guys from ausmicro have not reply back on three messages I send, So I guess my option will be stacking 4562s FETs BTW EGR has 8958A FETs too but I guess the 4562s are better, is this right ?
Thxxx.
Cheers
2008.10.20, 11:34 AM
it would be the same as a 2x3 on the am boards,the 4652's will handle more current but the 8958 will be smoother.
1 bottom and 2 top will be fine for the awd,just trim the top board cover a little
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
