Old 2015.02.08, 05:06 PM   #16
Jshwaa
Jshwaa's Avatar
Originally Posted by Solo1 View Post
do you know and could you show me which components are for the receiver?
In the lower left of the above pic, you will find the receiver module. They compacted the entire radio into the square IC labeled "A 7105 AMR23910"
And then on the bottom-side...
The part on the lower right with the white goo on it is a trimmer inductor for tuning the receiver for a specific frequency band. The receiver IC can then switch channels within that frequency band on command so that you can operate multiple mini-z's together without having to mess around with crystals. Oh and on the upper-left is the receiver IC's local oscillator. Forgot to take the opportunity to measure that frequency, but it is the receiver IC that uses a trick called 'phase lock loop' to multiply that frequency in order to be able to demodulate the 2.4GHz carrier and extract the command information.
Old 2015.02.08, 05:22 PM   #17
Solo1
Old nut
Thanks! nothing like learning something new!
Solo1 is offline   Reply With Quote
Mini-Z Brushless Motor Specs arch2b Motor Tech 17 2020.01.03 11:58 AM
Motor causing glitching on ASF wight Mini-Z AWD MA-010, MA-015 5 2010.08.11 01:41 PM
Prototype 98-102mm Motor Mount Ronac New Products 50 2010.02.23 09:37 AM
Mini Speedway Kyosho Stock Motor Cleaning Test schmenzer Motor Tech 3 2008.02.25 12:20 AM
Tips and Tricks on the NML SSV.3 NOMOTORLIMIT Motor Tech 1 2005.02.20 03:49 PM
