Old 2008.02.03, 02:29 PM   #1
newbitowner
newbitowner's Avatar
xmod evo on awd chassis
my awd is currently set at 90mm and i just got an idea to mount a xmod evo body.
anyone have pics? can you guys point me to the right direction?
newbitowner is offline   Reply With Quote
Old 2008.02.03, 05:38 PM   #2
byebye
byebye's Avatar
I posted up the one I did. It's in the "post pictures of your awd"
Kris
Old 2008.02.03, 05:47 PM   #3
newbitowner
i remember seeing one there about 6 months ago, so i looked but could not find it...do you remember around what page?
or can you re-post the pics here? how long did you set the chassis at?
Old 2008.02.03, 06:21 PM   #4
byebye
byebye's Avatar
http://mini-zracer.com/forums/showpo...&postcount=709
What I did was I put the side clips on the awd first. I think I taped them. Then I put the body over it. It all fit perfect. I marked the body then pulled the clips and glued the piss out of it. I then took a front body clip(EVO V go figure) and modded it to fit. It was perfect.
I have pics but the gallery is down. It's in my NEW gallery link in my sig.
Kris
Old 2008.02.03, 06:29 PM   #5
newbitowner
thanks!
i'll be checking to see if the galleries are up.
did you use hot glue? (i need one) how long is the chassis set at? i think my ae86 is at 90mm, hopefully so is your evo.
Old 2008.02.03, 06:33 PM   #6
byebye
byebye's Avatar
It's 94mm and I used super glue and lots of it.
I sent you a PM
Kris
Old 2008.02.03, 11:28 PM   #7
been wanting to ask... how durable are those xmod bodies compared to kyosho autoscales?
Old 2008.02.04, 03:24 AM   #8
HammerZ
Master of Thrash
HammerZ's Avatar
Those things are almost indestructable, very toy like. Weight is the big factor here. I have seen many Xmods threads on different forums about Mini Z bodies on Xmods. About the only real difference is the Mini Z bodies have far less screws for all the add on parts, overall lighter.
Old 2008.02.04, 07:34 AM   #9
byebye
byebye's Avatar
x2-They are kind of heavy and have lots of screws. Cool thing is the body kits of course. Too bad they aren't compatible without modification.
Kris
How to reinforce AWD Chassis? ub0211042 Mini-Z AWD MA-010, MA-015 28 2008.04.14 06:10 AM
MA-010 AWD Chassis Body Mount Defect soulstice Kyosho 14 2008.01.17 05:38 PM
Interest Level of my AWD chassis I keep rambling about. Draconious Miscellaneous Discussion 22 2006.09.05 05:21 PM
difference between AWD chassis and AWD Readyset bottlefocker Beginner Questions 14 2006.08.27 06:44 PM
just got my AWD chassis Capt. Oversteer Mini-Z AWD MA-010, MA-015 2 2006.01.06 11:07 PM
