Fly over jumps and do wheelies indoors! Run riot with a big-tire Mini-Z!
Massive pneumatic rubber tires are equipped to the compact precision structure of the Mini-Z chassis. This big tire machine successfully built on the Mini-Z chassis, boasts a running style never experienced before. Its destructive running power will dominate your own indoor off-road courses. With plenty of suspension stroke, you can turn your living room into an off-road obstacle course. Run right over the mountain of magazines, the undulating carpet section, and the rocky section built from some ashtrays. Then set up a spectacular jump! Perform and control wheelies just as you envisage. An optional motor adds even more grunt and energy in lifting the front end. The Mini-Z Monster creates a new indoor motor sport category. Big trucking performance in a small package. Gather your family and friends together and start a big off-road challenge in your living room!
Chassis Technical Data
Length 170mm
Width 127mm
Height 61mm
Ground Clearance 21.5mm
Wheelbase 105mm
Tread (F/R) 95mm
Weight 285g (approx.)
Tires (F/R) 47 x 32 mm
Gear Ratio 18.3, 20, 22, 24.4 : 1
Motor 130 Type
Maximum Ascent Angle 45°
Features
Electronics Configuration
(No image) Standard AM radio system combines the receiver and speed control for efficient running and precise control. New RA-4B FETs allow better power handling.
Special Editions
Mad Force Special Edition
Option parts included as standard for improved performance.
Create some off-road mayhem right in your living room with the awesome mini monster truck. The popular MINI-Z Monster now comes fitted with a variety of high-grade optional parts as standard. The Readyset package format means all you need to do is set the batteries (sold separately) to be ready for off-road action - indoors! Special T3 color scheme adds the finishing touch to this stand out special edition.
Special Edition Features
Oil shocks on front and rear produce excellent damping effect and stability.
Three sets of four coil springs included (red, green and yellow) for choice of shock tension settings.
X-SPEED MINI-Z Motor V included as standard!
Full ball bearing specifications realize ultra high-efficiency and longer run times!
Uni-directional pattern radial tires let you power over any terrain.
Color nylon nuts not only prevent loosening, but also look sharp too!
Sparkling chrome under guard to protect chassis
Stunning molded plastic body painted and complete with markings and special gloss coat sits atop of a fully assembled chassis - just add batteries to operate.
The fine detail of the immaculately finished body is protected by a special gloss coat finish.
SP Limited/Hummer H2 SP Limited
Fitted out with optional performance parts for a unique American look and feel!
Experience the power and passion of the MINI-Z Monster. Charge over your own indoor off-road obstacle course and enjoy the power to perform wheelies. The proven reputation of the MINI-Z MONSTER will be further enhanced with the addition of a range of optional parts in this Readyset package that only requires batteries (sold separately) to be added, so you can enjoy the powerful and efficient performance of the MINI-Z MONSTER almost without delay. With a finish to match the SP Limited title, you can take on the wilderness inside your own home.
SP Limited Special Features
Front and rear oil shocks.
Green and yellow setting springs included in addition to standard red coil springs.
X SPEED MINI-Z MOTOR V included for extra power and torque.
Full ball bearing specifications for ultra smooth efficiency to maintain power longer.
Special blue nylon nuts look sharp on the wheels! Slip resistant for added reliability.
Chrome wheelie bar for better wheelie performance.
Sparkling chrome bumper protects the chassis.
Circuit breaker to protect motor and amp from overloading.
Pre-assembled chassis and pre-painted and marked plastic body. Just insert batteries to start.
Top picture property of Herman C., used on this page with permission.
Other images and text are property of Kyosho Corporation, and used on this page only for informational purposes.
