Old 2018.12.23, 12:36 PM   #1
Kacordy
MR-03’s, motors don’t run?
So I have 2 new MR-03’s and the motors don’t run. Took one out of the box, bound it, and only the steering works. 100% no motor response. 2nd car ran two full battery cycles on the track. Installed new batteries, car has steering, motor will not run. What is the best way to trouble shoot and get these cars running.
Thank you for some suggestions to fix.
Kacordy is offline   Reply With Quote
Old 2018.12.23, 12:51 PM   #2
TPDazzle
Make sure the motor wires are screwed down to the board. It is a simple thing but a loose screw caused my car to have the same symptoms once.
Old 2018.12.23, 12:55 PM   #3
SuperFly
bitPimp
SuperFly's Avatar
Can you easily turn them by hand, if you rotate the spur gear with your fingers? I would double-check gear mesh that it's not too tight, and also check the screws that hold the motor wires to the board.
mini-z gallery
PDX Mini-Z
Old 2018.12.23, 02:31 PM   #4
briankstan
briankstan's Avatar
the yellow square cap on the motor is essentially a breaker. usually they can be reset buy turning off and on, but if they are defective maybe that is your issue.
try removing one and see if that solves your problem.
Old 2018.12.23, 02:32 PM   #5
If you can solder, I would remove the fuse on the motors.
Old 2018.12.23, 04:15 PM   #6
Kacordy
Perfect, I will try the above. Yes, I can solder. Thanks guys
Old 2018.12.23, 09:25 PM   #7
Kacordy
I found the black wire where it screws to the board broken at the factory solder joint. It’s now fixed and running. The 4th new car still does not run even after I disconnected the yellow square cap.
Old 2018.12.23, 09:41 PM   #8
Pull the motor wires fron the screw terminals and connect them to a single AAA (hold the black wire to the negative tab and touch the red to positive. If the motor spins, then warranty the car with kyosho. If the motor does not spin, contact kyosho and see if they can send you a replacement motor. Kyosho is usually very good about warranty replacement.
The stock motor wires are quite stiff which puts strain on the solder joints. I almost always replace them with more flexible wire and hard wire to the PCB. I am always a little nervous about a motor terminal screw coming loose... I would test thoroughly before soldering to the pads on the board, but the solder is a much more secure connection than solder and a screw terminal.
Old 2019.01.06, 05:18 PM   #9
ZacMaster
What is everyone using for more flexible wire?
Andrew, Basement Racer
32332W-B McLaren F1 GTR White
KS Comp Med Slick Fronts, Super Soft Radial Rears
Silver Carbon T-Plate #3
Shield Hub Dry Ball Bearing Set
Interchangeable Front body Mount
Alum Battery Covers
Precision Gear Differential 64P 53T
ZacMaster is offline   Reply With Quote
Old 2019.01.06, 05:23 PM   #10
Turnigy makes some good stuff in various gauges.
FS: Atomic motors pinwc4 Mini-Z Marketplace 1 2008.06.25 07:53 PM
Just How Important Motors Really Are: MagicMan Mini-Z Science 10 2006.04.05 05:08 AM
Tamiya motors... Mini Z GT Motor Tech 11 2002.06.01 07:10 PM
motors matter? runtracer Parts and Hop-ups 4 2002.02.20 02:13 AM
gpm motors vs. x-speed herman Parts and Hop-ups 7 2001.12.14 03:31 PM
