Old 2006.03.07, 07:06 PM   #1
bcuzau
GPM .. they have many parts.. are they all available?
GPM sure has many parts for the MA01 on their website.. but are they all available? I want to get the rear bottom part.. I saw two different versions. One completely machined from aluminum. and another with the carbon fiber piece at the bottom.. anyone have one?
My Mini Inferno Gallery
bcuzau is offline   Reply With Quote
Old 2006.03.08, 01:51 AM   #2
sciencemike
sciencemike's Avatar
Saw the carbon fiber one 3 weeks ago at R*C*M*A*R*T.Sold out..
sciencemike is offline   Reply With Quote
Old 2006.03.11, 05:45 PM   #3
mini-z
Administrator
mini-z's Avatar
Post Part #s and we'll get them in!
Old 2006.03.12, 01:43 PM   #4
Nightcargo
MINI-Z AWD USD PRICELIST
Color Notification: Blue/Purple/Black/Grey Silver/Silver/Golden Black
PART ID DESCRIPTION
MZA002 ALLOY COMPLETED LOCK NUTS - 4PCS
MZA012A ALLOY FRONT GEAR BOX COVER - 1PC
MZA013A ALLOY REAR GEAR BOX COVER - 1PC
MZA013B ALLOY REAR GEAR BOX LOWER TRAY WITH SCREWS - 1PC SET
MZA018 ALLOY MOTOR HEAT SINK HOLDER - 1PC
MZA018/A1 ALLOY MOTOR SPACER (MOTOR GEAR 15T W/MAIN GEAR 31T) (MOTOR GEAR 17T W/MAIN GEAR 19T ) (MOTOR GEAR 19T W/MAIN GEAR 27T) - 1PR
MZA018/A2 ALLOY MOTOR SPACER (MOTOR GEAR 17T W/MAIN GEAR 31T ) (MOTOR GEAR 19T W/MAIN GEAR 29T) (MOTOR GEAR 21T W/MAIN GEAR 27T) - 1PR
MZA018/A3 ALLOY MOTOR SPACER (MOTOR GEAR 19T W/MAIN GEAR 31T ) (MOTOR GEAR 21T W/MAIN GEAR 29T) (MOTOR GEAR 23T W/MAIN GEAR 27T) - 1PR
MZA021 ALLOY FRONT/REAR KNUCKLE ARM - 1PR
MZA031F/1/G ALLOY FRONT KNUCKLE ARM HOLDER (1MM) WITH SCREWS - 1PC SET GPM DESIGN
MZA031R/0 ALLOY REAR KNUCKLE ARM HOLDER - 1PC
MZA031R/-0.1 ALLOY REAR KNUCKLE ARM HOLDER (-0.1MM) - 1PC
MZA031R/-0.2 ALLOY REAR KNUCKLE ARM HOLDER (-0.2MM) - 1PC
MZA031R/-0.3 ALLOY REAR KNUCKLE ARM HOLDER (-0.3MM) - 1PC
MZA031R/+0.1 ALLOY REAR KNUCKLE ARM HOLDER (+0.1MM) - 1PC
MZA031R/+0.2 ALLOY REAR KNUCKLE ARM HOLDER (+0.2MM) - 1PC
MZA031R/+0.3 ALLOY REAR KNUCKLE ARM HOLDER (+0.3MM) - 1PC
MZA031R/0/G ALLOY REAR KNUCKLE ARM HOLDER WITH SCREWS - 1PC SET GPM DESIGN
MZA041 ALLOY FRONT/REAR GEAR DIFFERENTIAL JOINT - 1PR
MZA048 ALLOY STEERING ASSEMBLY WITH PIN - 1SET
MZA049/0 ALLOY STEERING PLATE (0 DEG) - 1PC
MZA330GTR ALLOY FRONT BODY LOCK PLATE FOR SKYLINE GT-R (R34) - 1PC
MZA331R ALLOY REAR SKID PLATE WITH SCREWS - 1PC SET
MZA0345SP FRONT/REAR (0.3MM,0.4MM,0.5MM) COIL SPRING 5.2 MM LENGTH - 3PRS SET
MZA0352SP FRONT & REAR (0.3MM) COIL SPRING 5.2 MM LENGTH - 2PRS
MZA0452SP FRONT & REAR (0.4MM) COIL SPRING 5.2 MM LENGTH - 2PRS
MZA0552SP FRONT & REAR (0.5MM) COIL SPRING 5.2 MM LENGTH - 2PRS
MZA05751 ALLOY SHIMS USE FOR KNUCKLE ARM (THICK 0.5MM & 0.75MM & 1MM) - 12PCS SET
MZA2105 ALLOY SHIMS USE FOR KNUCKLE ARM (THICK 0.5MM) - 4PCS SET
MZA2107 ALLOY SHIMS USE FOR KNUCKLE ARM (THICK 0.7MM) - 4PCS SET
MZA2110 ALLOY SHIMS USE FOR KNUCKLE ARM (THICK 1.0MM) - 4PCS SET
MZA208C ALLOY FRONT/REAR UNIVERSAL SWING SHAFT (CVD DESIGN) - 1PR
MZA303 ALLOY BATTERY HEAT SINK MOUNT - 1PC
MZA621T COPPER FIRST SERVO GEAR - 1PC
MZA622T COPPER SECOND SERVO GEAR - 1PC
MZA623T COPPER THIRD SERVO GEAR - 1PC
TMZAFSS TITANIUM FULL SCREWS SET(2X5KM-2PCS, 2X5PM-8PCS, 2X6PM-12PCS, 2X6KM-4PCS, 2X8PM-2PCS) - 28PCS
TMZA025E TITANIUM MAIN SHAFT - 1PC ECONOMY VERSION
MZABEARING FULL BEARING SET - (2x5x2.5mm-2PCS) & (3x6x2mm- 8PCS) - 10PCS - NET PRICE
I personally would be interested in the following in the grey silver color:
I would also like to know what these are, from what I understand the top covers are also knuckle holders:
Anyone know of alloy pinon/spurs and diffs?
Thanks!
Nightcargo is offline   Reply With Quote
Old 2006.03.13, 05:50 PM   #5
bcuzau
Can you post or email me a price including shipping to Canada? Are all parts avail in all listed colors?
Last edited by bcuzau; 2006.03.13 at 05:51 PM. Reason: forgot to subsrcibe to thread.
Old 2006.03.14, 08:12 AM   #6
will16
I am definitely interested in the alloy rear lower. Been looking for it. Do you have it??
will16 is offline   Reply With Quote
Where to find replacement screws for GPM parts TuNeR1989 Mini-Z Monster MM-01 4 2006.01.24 10:46 AM
mr2 alloy gpm parts for trade West.F1 Miscellaneous Discussion 0 2004.07.07 01:49 PM
GPM Overland parts arrived Mondo Mini-Z Overland MV-01 10 2003.01.21 09:50 AM
GPM Parts for F1 mini-z Mini-Z F1 MF-010, MF-015 5 2001.12.20 03:15 AM
