Old 2008.05.15, 06:15 AM   #31
kryten
kryten's Avatar
Really? I thought the minimum fets for a chili was a 2x2 of 4562's? I was under the assumption that a chili would fry a 2x2 stack of 3010's?
Old 2008.05.15, 08:06 AM   #32
mk2kompressor
at the Bleeding Edge
mk2kompressor's Avatar
a 2x2 of 3010 will run the chile but prolonged use will damage them over time
especially in an awd
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Bleeding Edge Racing UK
Old 2008.05.15, 12:45 PM   #33
Kamer
Kamer's Avatar
i guess it comes cause the fet's are 4x1 so the not heating up that much.
@mk2kompressor i running it since begin of march twich a week usuell and still nothing..//knock on wood
Kamer
Kamer is offline   Reply With Quote
Old 2008.05.15, 12:57 PM   #34
Tjay
Tjay's Avatar
I tried the chilli motor on my 2wd and awd 2.4ghz with stock 3010's. They work but the battery drains faster and there's no punch on the car. It almost feels like the car is on high gear but it's not. I swap the fets with 4562's and the car has gotten fast with better runtime and doesn't heat up the fets as much.
Herman: next year I'll let you run this awd, asf w/ 4562's and chilli motor. It is insane... on the straight it looks like it wants to fly .
Old 2008.05.15, 02:48 PM   #35
mk2kompressor
Kamer
exactly,they are not stacked ontop of each other so less heat build up,also no 2 motors are exactly the same,to be on the safe side go for higher current fets
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Old 2008.05.15, 08:06 PM   #36
looking forward to it..
Old 2008.07.10, 06:51 PM   #37
oif03vet
Any updates as far as anyone using the 4562 fets? I just got the conversion board for my 2wd and am thinking about making the fet swap.
oif03vet is offline   Reply With Quote
Old 2008.07.10, 06:59 PM   #38
Flashsp-2
motor guru
Flashsp-2's Avatar
@oif03vet--I'm not using 4562, but I did replace the stock FETs with SP8M4 on my ASF mr02 stock car. It's noticeably more punchy, while the throttle is still linear and controllable. Definitely a plus when running the PN 70t motor. Interesting tag by the way, I was in Saudi in 03 and Balad last year
Old 2008.07.11, 01:48 AM   #39
Tjay
Tjay's Avatar
I'm running 4562's on my mr02 that I use with PN stock motor. Noticeable increase in speed/punch and is more efficient.
Old 2008.07.22, 10:43 AM   #40
Cherub1m
Slip Angle Chaser
Cherub1m's Avatar
Originally Posted by CristianTabush View Post
AWDs can be deceiving. You can get the power down, but if you overpower it, the car starts spinning the wheels without you really noticing. Just because all 4 wheels pull, it does not mean that they won't loose grip on the track. My choice here is a 2x2 stack of 4562's, sometimes, just a single 4562 on top of the stock 3010.
If I understand this correctly I could leave the stock fets on my 2.4 pcb and just add 4562 fets on top of the top stock 3010 fets? Will mixing these fet cause problems? Will this set up be able to handle a PN Anima II and a PN Xeric with no problems?
Hope the answer is yes, because I dont want to remove fets .
Also, I think the stock fets have enough punch. I just dont want to burn up anything if I have to run an Anima 2 or a Xeric.
Philip Vincent
Old 2008.07.22, 11:22 AM   #41
Davey G
Need a mini z Painted????
Davey G's Avatar
Philip: The answer is YES. Cristian is correct, just put another layer of fets on top of your stock 2.4 double layer of 3010's and you'll be good to go!
Dave Graboski
DG Designs
Old 2008.07.22, 11:58 AM   #42
mk2kompressor
ive just put an extra layer of 3010 on top of the originals,it feels good so far with the pn stock motor
Team B.E.R.T
MR02/3 eating MA010
MR-03
HFAY S9 F1 Winner
Sinister V1
MRCG Prototype
MRCG 1.0
Old 2008.07.22, 02:21 PM   #43
Cherub1m
Slip Angle Chaser
Cherub1m's Avatar
Great, thanks Dave.
Philip Vincent
Old 2008.07.23, 09:57 PM   #44
oif03vet
Flash, my LAR unit was attached to 1st Marine Division, we spent some time in Kuwait before the war started and then ran the guantlet throughout Iraq from the first day of the war until September. Fun times!
Old 2011.02.21, 10:03 PM   #45
fraga
Javier
fraga's Avatar
So if I understand this correctly, you guys added only 1 layer of FETs to the top FETs, for a total of 6 FETs, 4 on top and 2 on the bottom. Did I got this right?
fraga is offline   Reply With Quote
2X2 +1 FET stack Dougboy Mini-Z Science 13 2006.10.12 02:13 PM
fet stack Dustin Miscellaneous Discussion 4 2005.03.14 04:22 PM
FET Stack Question Broke! terraz Mini-Z Science 0 2004.02.21 11:05 PM
What motor with FET stack warnoffroad Mini-Z Overland MV-01 0 2003.04.21 06:44 PM
Stack FET BJS-TF Mini-Z Science 24 2002.10.11 10:18 AM
