Old 2011.02.21, 11:26 PM   #46
Cherub1m
Slip Angle Chaser
Cherub1m's Avatar
Originally Posted by fraga View Post
So if I understand this correctly, you guys added only 1 layer of FETs to the top FETs, for a total of 6 FETs, 4 on top and 2 on the bottom. Did I got this right?
Nah, 8 fets total, 2 on top of the 2 stock fets and 2 on bottom on top of the bottom 2 stock fets for a total of 8 fets.
In the past I was removing the 4 stock fets and adding a 4 new high powered fet like the 8858 faichild fets but lately I've been just adding fets on top of the stock ones.
Philip Vincent
Old 2011.02.22, 10:54 AM   #47
fraga
Javier
fraga's Avatar
Got it. Thanks Philip!
Would you run this setup (8 FETs) with a 70t? I been reading comments that a 70t runs faster with only 4 total FETs, but mine feels slower with 4 FETs than it did with my AM board that had 6 total FETs. That is why I was thinking of going with 6 total (only adding 1 layer to the top).
fraga is offline   Reply With Quote
Old 2011.02.22, 04:15 PM   #48
Cherub1m
Slip Angle Chaser
Cherub1m's Avatar
I am no expert on fets but from what I notice (I didn't believe it would make a difference before since the 70T does not pull much amps) but 8 fets for a 70T motor made a noticeable difference for me at my home based mini 96. I haven't tested it out on a full size track at the LHS yet but soon will. Also, I've heard some racers for 2wd mod would only have a total of 6 fets because they felt 8 fets gave them to much punch for mod. For my AWD I just recently added 4 more fets for a total of 8 fets because I like punch with the AWD(I hope I like it haven't tested it in a full track yet). For my 2wd Mod cars all have only 4 8858 fets except for one that has 4 3010 fets and 4 8858 fets (total 8 fets) that has not been tested on a full size track also so I am just waiting to see if the punch is going to be to much or just fine. In short this week is going to be a test and tune day for me, I'll let you know what happens.
Philip Vincent
Old 2012.08.24, 06:04 PM   #49
danjoyy25
stacking 4562 on top of OEM 3010 fets???
Just finished changing the original 3010 fets on my Mr03 with a double stacked 4562 fets just on the top side, so 4 in total. Everything works and can feel the difference but having said that I think I nearly broke the PCB so I won't be game enought to take original FETS again anytime soon as I still have an F1 and AWD to do.
I have read other post were people stack on top of OEM fets so just want
to find out if its the same process as I think for me its alot easier to do as Im not taking the risk of ruining the board.
Can I just put a single/double stacked 4562 of top of the 3010 fet and solder the input side pins individually and on the output side solder all 4 pins together???
danjoyy25 is offline   Reply With Quote
2X2 +1 FET stack Dougboy Mini-Z Science 13 2006.10.12 03:13 PM
fet stack Dustin Miscellaneous Discussion 4 2005.03.14 05:22 PM
FET Stack Question Broke! terraz Mini-Z Science 0 2004.02.22 12:05 AM
What motor with FET stack warnoffroad Mini-Z Overland MV-01 0 2003.04.21 07:44 PM
Stack FET BJS-TF Mini-Z Science 24 2002.10.11 11:18 AM
