Old 2015.03.31, 08:11 AM   #1
ivanmartin18
RF-901SM Module Flashing
Hi guys,
I've a problem with my Helios + 901SM module. When I switch ON the radio the led keeps flashing all the time. It never goes to solid red.
If i try to bind following the instrucions manual procedure, it "works" fine: led ON, then OFF and after releasing the pushbutton, again darker led ON. But when i power OFF and ON the radio, it flashes again.
I tried with another module and it works perfectly, so the problem is not the radio but my module.
Any ideas?
Thank you!
P.D: I've duplicated the post from here http://mini-zracer.com/forums/forumdisplay.php?f=94 Sorry if it's not OK.
ivanmartin18 is offline   Reply With Quote
Old 2015.03.31, 08:56 AM   #2
My first suggestion would be to attempt contact with KO through their thread here on MZR and or then sending them the module for evaluation and repair.
Old 2015.03.31, 09:45 AM   #3
ivanmartin18
Already done, waiting for an answer.
Thanks for the suggestion.
WTB: Ko Propo 901sm Module (#15502) briankstan Mini-Z Marketplace 0 2014.12.30 11:23 AM
KT-18 convert to Module 901SM Joel2010 Transmitters, Receivers and Crystals 9 2014.02.09 12:19 AM
FS-KO EX1 UR with 901sm 2.4ghz module MDRTales Mini-Z Marketplace 1 2014.01.01 01:25 PM
WTT 901s for 901sm or spektrum module Billbrasky Mini-Z Marketplace 0 2013.11.20 11:53 PM
What about 901SM module ? mferrini KO PROPO 5 2008.05.30 12:24 AM
