I have spent some time looking at the MR03VE programming software from Kyosho. The profile files are saved as a .mbc, they are really an xml file.
There are 32 unique byte values stored.
I have mapped about 80% of the values so far and documented them. There are many bytes that can't be changed by the Kyosho software - lots of mystery bytes!
If you're interested I can post the values I have documented so far, in a few days I should have finished with all of the them.
Yes, please do, this will save me some work.
I am not surprised that they are not all used, that was also the case with the previous mini-z's. They had 15 bytes of data, but the first generation ICS only used 7 of them, by the time the MR-03 came out they used 12 and the Brushless looked like it needed more than the 15 that the prior protocol had.
Power Is Nothing Without Control
OK, here are all of the values the Kyosho software lets you change.
The bytes are bolded and listed in order with the default values. For each option I have listed the software displayed value and then the corresponding stored value.
I did try messing with some of the values hoping to find the default steering endpoints but I noticed no change when altering various "unknown" values.
One I haven't played with yet which could really help people is the neutral brake option, if going to a higher value increases the drag brake people would find that quite useful.
Now I just need a source for a well priced mr03ve, I want a second one.
Having 2 cars in Stock form & all out Modified
makes testing comparing much easier from ICS.
Neutral Brake set max. at 5 makes huge different in generating Drag Brake as we use to in Brush Motors.
Also Punch at 5 gives it little more out of corners and Back Timing at 3 to give better response time in reverse.
MRX Mclaren MP-12CGT3 PN 43T LIPO: X2
MR-03 Mclaren MP-12CGT3 AT70T
PN 2.5 Mclaren MP-12CGT3 PN50T
MR-03 S2K Narrow AT60T Nihm
MR-03 BRZ Narrow PN70T Nihm
MR-03 Enzo Ferrari GT Concept Xspeed SP2012
MR-03VE 2005 NSXGT AT 12000KV w/Lipo
MR-02 Nissan R390 GT Lemans 39T PN
AMZ Benz TC 8500KV
X Power IDT Ultra 5600KV Audi
X Power IMT Ultra 6800KV M3
MB-010 FT86 Comic Racer 39T PN
MF-015 Mclaren MP4-25 50T w/Lipo PN
MR-01 Mugen NSX-GT 02 X Speed Retired
dNaNo FX-101MM T2 XANAVI NISMO GT-R
MAJ'S HOBBY SHOP " A Place To Escape from Reality"! TD
214 State St. Suite 209
Hackensack, NJ 07601. 201-820-1347
LIVE Mini-Z RACING EVERY Fri at 7 PM.
Outdoor Saturday On Road Racing 1/8GTVE,1/10TC&USGT
32 bytes total
Thanks for this information, it will save me quite a bit of time. Have you looked at the communication that occurs on the serial port? Does it start with the same two bytes of D5 5A and end with a checksum?
Also is the order you put the bytes in below the order that they write to the car in?
I agree, if we can send a higher value such as 100 to the drag brake setting this would be very usefull. I only ran a MR03VE for a few minutes but immediately noticed that the drag brake was way to weak. It had already been set to the highest setting that the Kyosho ICS software let you program. However in seeing the information you provided the highest value it writes is a 70, maybe if we give it a higher value we can get more drag brake.
Thanks for your help with this
