Old 2019.03.03, 09:05 PM   #1
Smokey_truck
Guest
Posts: n/a
Exclamation Question on miniz transmitter module
I bought this radio from eBay
EX10 HeLios with RF-901S module 2.4 GHZ, will this work with ASF miniz?
Thanks for any inputs please.
Smokey
Old 2019.03.03, 10:40 PM   #2
Yes it will
my custom body album...
Old 2019.03.03, 10:48 PM   #3
Smokey_truck
Guest
Posts: n/a
Originally Posted by cowboysir View Post
Yes it will
Thanks for your response, I checked on KO PROPO site on compatibility and it says only RF-901SM module and the one I bought wasRF-901S module, do you still believe it is compatible?
Smokey
Old 2019.03.03, 11:09 PM   #4
It needs to be the blue 901-SM module, not the red one.
Old 2019.03.04, 06:02 AM   #5
The 902SM module for the newer Euros radio is backwards compatible to the Helios. The 901SM module from the Helios however is not forward compatible. If using the 902SM in the Helios you will lose some of the features that the module provided like the setting card feature.
Old 2019.03.04, 07:43 AM   #6
Smokey_truck
Guest
Posts: n/a
Trying to figure out your answer, so are you saying 902SM will only work with Miniz?
Smokey
Old 2019.03.04, 09:53 AM   #7
The 901SM AND 902SM modules will work with the Helios and Euros. The 901SM will work with the Helios only. I bring this point up because of the rarity of both modules. Knowing that there are two possibilities only broadens the search parameters.
Old 2019.03.04, 06:10 PM   #8
I apologize...I misread your first post.
Old 2019.03.04, 09:46 PM   #9
Smokey_truck
Guest
Posts: n/a
No need to apologize, if there is a big difference in one letter in the model number can lead to confusion, manufacturers should name the clearly.
Smokey
Tags
ex-10 helios
FUTABA 3PKS with 2.4 miniz module FOR SALE phantom_racer Mini-Z Marketplace 0 2010.05.29 03:28 PM
2.4ghz module for EX-1 Mars Transmitter ChiMiniRc Transmitters, Receivers and Crystals 1 2010.04.26 09:37 PM
HELP!!! Transmitter Question - 2PL simonseize Transmitters, Receivers and Crystals 1 2007.11.24 05:05 PM
KO mini-z Module compatibility question rap66@rcracing. Transmitters, Receivers and Crystals 5 2005.10.27 10:33 PM
