2018.09.12, 05:02 AM
Reverse .. only sometimes !!
My new Mini-Z awd sports is having a reverse response problem
Already reset transmitter many times, rebinded but keeps happening. The reverse just works when it´s in a good mood!
CHECK THE VIDEO PLEASE
Can anyone help me on this one?
2018.09.12, 11:01 AM
Have you tried setting the throttle trim?
2018.09.12, 04:41 PM
The transmitter is the stock one KT-19 .... I have this car just for my friends to play when they come over, all stock and easy to drive! I just got it two months ago and one time i binded it with my "PRO" transmitter to try, all good but when I went back to rebind with KT-19 again, this problem started to happen!
2018.09.12, 08:39 PM
If it is fine with the Pro transmitter, but not with the KT-19 then I suspect a transmitter issue. Try fiddling around with the throttle trim and see if it helps. It might be set to far in reverse.
2018.09.13, 09:04 PM
Kinda odd, I just looked at the instruction manual of the kt19 and surprisingly, it doesn't have a throttle trim... there's a steering trim (#5 on the diagram), dual steering rate (#6), and a light unit trim (#7). Anybody know how to set the throttle settings? Or if there is a throttle rate? Or maybe there is a way to reset the board or tx...
2018.09.13, 09:16 PM
Found this.... hope this helps...
Scource: click here ---> how to reset KT19
To reset the transmitter:
(1) Turn off the transmitter if it is on.
(2) Make sure that the steering trim knob is at the center position
(3) Turn the G.SPD L (speed limiter, right side) knob fully to the counterclockwise direction.
(4) Position of G.SPD H (LED control, left side) knob does not matter.
(5) Turn the steering wheel to the fully right position and push the throttle away to the full-brake position and hold them.
(6) Turn on the transmitter. The LED should flash rapidly; this means you are now in the factory mode.
(7) Release the steering wheel and throttle lever.
(8) Turn the steering wheel fully to the left, right, left and right, and then release it.
(9) Pull/push the throttle lever to full-throttle, full-brake, full-throttle, and full-brake, and then release it.
(10) Turn the G.SPD L knob to the right most position. The LED should become solid.
(11) Turn off the transmitter and on it again. You are done.
2018.09.13, 09:20 PM
I didn't know there was no throttle trim on that radio. That is really weird, such an important thing to have. But, at least they have a trim for the LED lights, that's a must have....
2018.09.13, 09:28 PM
So did I... lol trim for LED lights... yep definitely more important than steering trim! lol
2018.09.17, 01:17 AM
Any news on this? Wondering if the reset tips work... can anyone confirm? Thanks...
2018.09.17, 01:28 PM
Thanks a lot .... Just tried it and it solved the problem!!!!
You guys are the best
2018.09.17, 10:02 PM
Nice to hear that the tips work! Maybe a sticky on how to reset the KT19 should be in order...
Still can't believe it doesn't have a throttle trim....
Forgot to add another step...
(12) you do the hokey pokey and you turn yourself around... that's what it's all about... hehehe
2018.09.18, 06:59 AM
I believe it is sticky in another subforum section.
2018.09.18, 07:23 AM
It is. Third item down in transmitters, receivers and crystals.
2018.09.18, 11:43 AM
Aha... you're right here's the link to that thread...
http://mini-zracer.com/forums/showthread.php?t=39628
Can't believe I gave the same answer way back in 2014!!! LOL
2018.09.18, 07:36 PM
Once again .. thank you very much !!!
