Old 2006.05.16, 08:44 AM   #1
fastskater21
Faster, Longer running, Mini-Z Formula Boats
Hello, This shows my surface drive modification to the Formula boats series.
It involves removing the power robbing strut propshaft assm and putting
the prop directly on the output shaft. This gives the prop more
RPM closer to the surface and allows the motor to run at a more
effient pace. I then made a styrene rudder that is much thinner than
the stock piece. I have noticed some cavitation at times, but man
does it run alot longer and is faster than the stock setup.
it also has the Aquaspeed motor and prop sets that I am still experimenting
with. I still have some hull tuning to do as well. My goal is to make these
boat run faster, longer and better without anyone having to invest outside
the orignal parts variety to keep cost and complexity down. I will post any
new funtional developments as I try them out and they work to my
desired levels.
fastskater21 is offline   Reply With Quote
Old 2006.05.16, 09:00 PM   #2
cool mods...
can you post pics on the old parts (stock) vs. the modified? or before and after shots?
Old 2006.09.04, 05:11 PM   #3
tmmulloy
Mini Boat
Hello , I noticed your posts on the mini For. boat and I wanted to ask you if you think there is a hop up battery ? I wondered if a LIPO or LION battery could be used if so what kind . I also wanted to ask you where a improved propeller could be bought. Thank You Tim
email Tmmulloy2002@yahoo.com
desired levels.
tmmulloy is offline   Reply With Quote
Old 2007.11.18, 10:50 AM   #4
Yeap
Yeap's Avatar
desired levels.
hi there..
i've tried the suggested modification. the efficiency of the motor increases, run time increases. but i can't seemed to have the boat going faster that the stock setup. as a matter of fact it's actually slower
any possible reason for that?
Yeap is offline   Reply With Quote
Old 2007.11.23, 04:27 PM   #5
mikez
DGAF
mikez's Avatar
Send a message via AIM to mikez
cool mod
mikez is offline   Reply With Quote
Old 2007.11.28, 02:12 PM   #6
marc
Honda Insight Racer!
The boats are nice, but only good if you live near a pond.
Futaba 1/20 Scale Indy Cars Mondo Mini RC 54 2006.05.12 08:35 PM
help, fets and running time? Paradigma Mini-Z Racer MR-02 7 2004.02.10 09:24 AM
Mini Z or Micro RS4? Which is faster? Interceptor Mini RC 3 2002.05.08 09:26 PM
