How about this guys? To the guys that race the MA-01 competitively at your local RCP track post your set ups here for others to try, I know there is alot of different factor that the set up you posted here might not work on others track but you can just get an general idea of what people are running. I'm not sure if there is a MA-01 set up sheet existed so how about we do something like this? Please post if there is a set up sheet for the MA-01.
RCP Track traction - low, med, high
Layout - fast, technical
Gearing - ...
Body - ...
Wheelbase - ...
Motor - ...
Front:
Toe - ...
Camber - ...
Spring - ...
Lowering spacer - ...
Spring spacer - ...
Drive - diff, oneway, spool
Wheel offset - ...
Tire - ...
Special notes - ...
Rear:
Toe - ...
Camber - ...
Spring - ...
Spring spacer - ...
Drive - gear/ball diff
Wheel offset - ...
Tire - ...
Special notes - ...
Futaba l Muchmore l AHRP l Aldus Design l Atomic
HFAY OLPS Season1 Race 12 2nd place overall with 90 laps - 08:03.49 Video (my car is the white Ferrari 360GTC) (it took me a couple laps to settle into a groove )
-hobbycar
I'm going to try the Kyosho 20 Radials in front and maybe lower the front just a little bit more for the next race.
RCP Track traction - high
Layout - technical (2 mini96 rcp's + 2 extension packs put together)
Gearing - doesn't really mather but not highest gearing
Body - murcielago
Wheelbase - 98(extension kit)
Motor - pn speedy 05 BB(from mr02)
Front:
Toe - 0°
Camber - 1°
Spring - atomic red(soft)
Spring spacer - ...
Drive - ball diff atomic
Wheel offset - +1.5 narrow(should be 2.5 wrong wheels)
Tire - 30° atomic competition
Special notes - pn upper deck + camber knuckles for minimum friction
Rear:
Toe - 1°
Camber - 1°
Lowering spacer -
Spring spacer -
Wheel offset - +0.5 wide(wrong wheels, should be +3.5 or 4)
Tire - 20° atomic competition
Special notes - pn upper deck and camber knuckles for minimum friction, bleu/gray chassis, fet upgrade, motor heat sink, 3racing alloy swing shafts, titanium kyosho center shaft, ball bearings.
garage :
kyosho miniZ MR02 2.4Ghz
kyosho mini inferno : atomic tuned + brushless + 11.1V 3C lipo
HPI savage : 35 full fastlane alloy 4.6BB
hormann HT2 bigscale 26cc
team losi miniT PRO
team losi microT lipo
